k&n hi flow air cleaner for flhtcse
Old Sep 11, 2005 | 04:24 PM
HDF Tech's Avatar
HDF Tech
Default RE: k&n hi flow air cleaner for flhtcse
ORIGINAL: pilot1996
I'm waiting on this, and need the information. My blue one is coming apart, and I'm worried about putting pieces of it in my intake. Let me know what you find.
Mac
Mac, hoping to hear from them tomorrow (Monday) at the start of business. Will let you know as soon as I hear and I'll also post in the DIY to update too.
Bill, I believe the stock size K&N 6 1/4 X 5 1/2 (tapered) X 2 1/4 will flow good up to 100/100 and is the stock K&N used in the stage 1 setup, but you're correct, more is usually better
On my previous WG, I went from the stock K&N in the stage 1 kit to the 1" taller zipper upgrade K&N and had to rejet it for better performance once I did it.
Old Sep 11, 2005 | 05:07 PM
John TN's Avatar
John TN
Bill, you are exactly correct on your statements, when I lost my breather when the bolts broke at the backing plate I had to hammer the stage one down just a little to get a good seal, I was in a hurry and didn't have time to do it correctly.
By the way I talked to Ness and they told me they had a problem a couple of years ago with bolt breakage, but have since then come out with new adapter bolt's that's supposed to not break, so all you guys that might have an older big sucker it's something to look at. If Mac goes with the stage II he will need a 8" diameter breather cover, I run the Ness 8" round breather cover, it's available in smooth or grooved, you can see them at the Ness sight or JP Cycles.
Old Sep 11, 2005 | 05:27 PM
John TN's Avatar
John TN
I wanted to add one other K&N filter for the big suckers or SE backing plates, it's a ultra high flow if you need that much, my friend runs this on his built 103, you have to put spacers in-between the breather cover and the outside of the filter. They are not cheap, but they do flow a huge amount of CFM.
http://www.bcheads.com/new.htm
Rusty7755
Nov 2, 2012 10:53 PM
Harley Dave69
May 2, 2008 06:22 AM
big cahuna
Sep 11, 2007 08:47 PM
fullthrottle
Feb 26, 2007 11:16 PM
Hog_fever
Sep 27, 2005 03:48 PM
