Leaky heads
Old Apr 27, 2023 | 04:07 PM
tasturbo86's Avatar
tasturbo86
My bad, I didn't realize Scotty had already tried to fix the thread seal.
1 demerit for me
Old Apr 27, 2023 | 04:47 PM
Scotty p's Avatar
Scotty p
It’s good. Machine shop said it’s not the threads, the problem is in the flatness where the plug tightens down to.
But of course it’s still leaking around the plug, so not the solution!!!
Old Apr 28, 2023 | 05:29 AM
eighteight's Avatar
eighteight
The angle of the spot face cut they made has to be perpendicular to the threads
Wonder how they measured that
Old Apr 28, 2023 | 06:45 AM
johnjzjz's Avatar
johnjzjz
We made a tool from an end mill that drops in the the thread and uses the thread length as a center guide its 2 pieces - a drilled insert ( pilot ) goes in then the tool so the threads are never in danger of being hurt
Indian - 45 and big twin share a 14mm thread and again some are 18mm < those are easy as a pilot is standard for converting to 14mm plug that most all flatheads have - the guy using the bridge port must be good at what he does or you end up doing nothing but reducing the distance
Old Apr 28, 2023 | 06:54 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Has anyone out experience leaky heads at the spark plugs?
Im getting a leaky gas/ oil black looking stuff at the spark plugs, mostly the rear head.
Was told that aftermarket aluminum heads have done this because the boss landing where the spark plug rest isn’t flat. So took to machine shop and had it trued up, but yet still leaking.
Whats the fix?
What year Harley? Show a picture of the bike, the head were the shop cleaned up the port. The sparkplug. Put some high spot blue on the and see if the plug rings it 36. If threads were not square with face, it's pretty involved getting them that way.
I would thread a plug on my lathe to a snug fit on the thread and a straight section to last word indicator to get it square.
Is your plug not a crush gasket ? The old school 45 bevel?
Now it is normal in 10,000 miles US to see black up the threads on a FI even. Aluminum when hot outgrows steel.
Class 2B threads have more then enough clearance for a crush gasket or 45 seat to square up and seal .
Old Apr 28, 2023 | 09:23 AM
tasturbo86's Avatar
tasturbo86
Default Tool for flat plug sealing surface
They may have used a tool similar to this Time-cert tool. The long piece threads into the head and will determine the proper angle for the sealing surface. The Wider piece slides over the first piece and cuts the sealing surface.
harley_jeff
Exhaust System Topics
Jan 23, 2023 03:17 PM
Akdawg
Apr 14, 2019 02:01 PM
harley#1
Aug 5, 2016 10:58 AM
misfitJason
Engine Mechanical Topics
Jun 19, 2015 01:49 PM
Haul Ass
Shovelhead
14
Apr 5, 2010 05:17 PM
