1985 FLHT Hard Starting
Old Sep 7, 2021 | 11:56 AM
bray/1985FLHTSC's Avatar
bray/1985FLHTSC
Stage II
Default 1985 FLHT Hard Starting
On first start of the day, when cranking engine, for the first 10-15 seconds of cranking the engine, there is no spark. But if you leave the ignition on and take a minute or so break. Then go back to cranking the engine, there is spark and engine will start right up. Let the engine sit and idle for a few minutes, the engine will loose spark and die. But it starts right back up and will run fine for 5-10 minutes before I shut it off. The bike has all the original factory ignition parts. Any ideas as to where to look for a fix? Thanks for your help.
Old Sep 7, 2021 | 01:42 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
This is the Forum Issues section. This is NOT a Forum Issue!
Izzo
Admin
Fxd 03
Forum Issues
Jul 17, 2021 07:33 AM
