copy and paste text issues.
Old Mar 11, 2023 | 02:25 PM
soldierbot's Avatar
soldierbot
Default copy and paste text issues.
When using "dark mode", sometimes text from a copied article appears as dark text and is unreadable, unless it is highlight with the mouse.
Conversely, I just found out that this is happening for members who do not use dark mode, the text is rendered as white and is unreadable.
I don't remember this ever happening prior to the launch of dark mode. Is there a way for tech to resolve this issue?
Old Mar 11, 2023 | 02:34 PM
pgreer's Avatar
pgreer
When I have had similar problems pasting text like that (formatting changed), I pasted to Notepad, copied form there and pasted the text in. Notepad removes background formatting. This may be different, but might be worth a try until something better comes along.
Paul
Old Mar 11, 2023 | 05:01 PM
snipit's Avatar
snipit
I don't remember this ever happening priorIf you quote someone you'll have to chang to the launch of dark mode. Is there a way for tech to resolve this issue?
If you quote someone just, change the text color to anything but black or white.
Old Mar 11, 2023 | 05:25 PM
soldierbot's Avatar
soldierbot
who has time for that ?
Old Mar 11, 2023 | 05:46 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Rounders will be along any minute to explain it all..........................I'm sure
Old Mar 12, 2023 | 06:24 AM
snipit's Avatar
snipit
And I thought I had way too much time on my hands!
Old Mar 12, 2023 | 06:29 AM
Ron750's Avatar
Ron750
I never use dark mode. I have noticed posts with very light print lately. Just get rid of dark mode. Turn down the brightness of your phone manually if you need to. It’s insane to make you have to select a different color to avoid the simpler process of just turning down the brightness.
Old Mar 12, 2023 | 04:10 PM
dennyo's Avatar
dennyo
Test tin test tin ? with notepad
Old Mar 14, 2023 | 01:14 PM
Robb M.'s Avatar
Robb M.
Internet Brands
this is not related to dark mode, it's just more noticeable now. The editor is WYSIWG so it copies existing formatting and preserves it without you seeing/knowing it. so if you copy text from a white background and paste it into dark mode, it's going to be black on dark. you can resolve this by tapping the 'source' button and then pasting.
FLYING_BURRITO_BROTHER
Forum Issues
Apr 26, 2018 02:51 PM
