Using quotes from other members
Old May 23, 2012 | 09:45 AM
Roadie53's Avatar
Roadie53
Default Using quotes from other members
When I post to a thread and try to insert a previous quote from anyone I dont get the box like other quotes have,only comes up with spelled out, Quote:[example]:Quote.
Do I have a setting wrong or what?
Old May 23, 2012 | 09:55 AM
Sweetbaboo's Avatar
Sweetbaboo
Are you clicking on the QUOTE button in the lower right corner of the person you wish to quote first? If not, and you're trying to insert someone else's quote after you've typed your post, then you will not get the quote box. But, don't quote me on that.
Old May 23, 2012 | 10:01 AM
Imold's Avatar
Imold
I looked at a few of your posts and didn't see any quotes. Are you just seeing what's in the reply box you type into and giving up? That just shows what you're talking about with quotes in text like you're describing, until you click on the advanced button below it, and then click on "Preview Post"; you should see what it will actually look like then. If it's still text, and posts that way, then I don't know what the problem is. Try quoting this post and we can see what happens.
Old May 23, 2012 | 10:02 AM
Imold's Avatar
Imold
Oh yeah, and what SweetB said...
Old May 23, 2012 | 11:28 AM
Roadie53's Avatar
Roadie53
Did this come out right on your end? Thanks for the reply
Old May 23, 2012 | 11:34 AM
Roadie53's Avatar
Roadie53
Looks like it came out ok Imold.Must have been me??!!
Old May 23, 2012 | 12:12 PM
Sweetbaboo's Avatar
Sweetbaboo
Good to go.
Old May 23, 2012 | 01:07 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Hey Roadie, you got it. Just thought I'd add a little tid bit of info for formatting things a bit nicer.
you can add your own quotes buy simply typing the html tags around the text you want quoted.
For example (I will substitute a zero for the 'O')
[QU0TE] this is an example quote [/QU0TE]
will result in this... (when i type QUOTE properly)
You can even nest the quotes, which means a quote inside a quote...
[QU0TE]
[QU0TE]
this is a nested quote
[/QU0TE]
[/QU0TE]
now spelled properly it looks like this...
Cool eh? Hope that is clear as mud.
Old May 23, 2012 | 02:23 PM
Roadie53's Avatar
Roadie53
Getting WAY too tech savvy for me on that last one zeus.Think I better just keep taking baby steps 'til I sorta figure this stuff out!
Thanks for the help.
Old May 23, 2012 | 02:36 PM
Imold's Avatar
Imold
Yep, and thanks to Zeus33, I learned about quotes in quotes, didn't know that.
