You're not using the right code from your photobucket. Check out the link that you're posting and the one I took from your album. Notice mine doesn't have an action view? In your album, use the link that the IMG section gives you...then change the image [IMG] tags to lowercase [img] tags.
And try resizing your pictures before posting them. Large ones aren't so nice for those who still use dial-up. 480x600 usually works nicely...unless it's for a signature...then use a smaller pic.
OK we can forget this ever happened.........
Thanks for your help 125, photobucket even provides img links, duh it helps if i pay a little attention some times
