Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Ferodo Brake Pads
Old Nov 19, 2014 | 11:11 PM
rcmonroig's Avatar
rcmonroig
Stage III
Default Ferodo Brake Pads
I have about 15,500 miles on my 2011 Super Glide Custom. At 11,000 miles I had a license harley repair shop replace the front and rear brake pads. They used Ferodo brake pads. 4500 miles later I needed to replace my rear tire. I take it in. The shop calls me and says I need front and rear pads and front rotor. I went down to the shop and to see for myself. Sure enough the pads were practically down to metal. I asked if the calipers were sticking. They said no.
My question is: Does Ferodo make that crappy a brake pad product or was this the result of poor installation?
Old Nov 25, 2014 | 09:09 AM
grbrown's Avatar
grbrown
Brake pads are like tyres, different brands have different service criteria and different service lives. Ferodo is a well known brand, but it may just be they don't last as long as stock pads and has nothing to do with installation. If each pad in a pair has worn down the same amount then the caliper is fine. If you don't like them try a different brand of pads next time, there are plenty to chose from!
Old Nov 26, 2014 | 06:42 AM
GraemeR's Avatar
GraemeR
I now only use Lyndall Gold pads on my FXR. Best stopping I have come accross and no brake dust at all.
Old Dec 14, 2014 | 04:54 AM
WildBill2566's Avatar
WildBill2566
I replace the stock pads with Lyndal Gold pads, at least as good stopping power as stock, but I really noticed a reduction in brake dust. It is the only pad I have used other than OEM, but I see no reason to change. They worked on my previous Softail and both my Roadkings. I can't speak as to longevity, as bikes were sold before another brake change was necessary, and it's a bit irrelevant as some are harder on brakes than others, I'm pretty easy on brakes. That said I think I put 8000 miles on the Lyndal pads on the RK and they didn't require changing.
RidemyEVO
May 4, 2016 01:50 PM
Cazimere
Aug 24, 2012 08:38 AM
hdman6
Feb 29, 2012 12:04 AM
rdondes
Dec 17, 2009 04:07 PM
sastrac
May 3, 2008 08:30 AM
