12 switchback rear springs
In your case, going with shorter shocks is going to reduce travel. While it looks cool, my understanding of shorter shocks is that they give a harsher ride with less cornering clearance. Also, you didn't mention which Progressives you went with. The 412's are not known to provide that much of an upgrade in road feel. I understand the 444's start getting decent performance, however, I believe all Progressives are either sprung "normal" or "heavy duty" vs. a spring weight more fine tuned for the rider.
In the $500'ish range, you have....
Progressive 444's - Provide adjustable preload and have a decent rebound/dampening system. Available in a broad range of lengths.
Hagon Nitro's - Provide adjustable preload and dampening. Sprung for rider weight. Available in a broad range of lengths.
Ohlins - I totally forget the model #, however, contact Howard at Motorcycle Metal. He builds these for your weight and riding style. I believe they are preload adjustable only and only come in 12.5"'ish and 13 3/8". These are closer to $600.
There may be other shocks in that price range, but these were the ones I targeted after researching.
If you go for a higher price point, a lot more options open up. For a lower price point, I think the Hagon 2810's for under $400 were the best performance available. The 2810's are also built for rider weight and are offered in a bunch of lengths.
