Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Master cylinder bleeder valve leaking?
Old Jun 10, 2020 | 06:46 PM
SmittyFXDL's Avatar
SmittyFXDL
Default Master cylinder bleeder valve leaking?
Has anyone experienced a rear caliper bleeder valve leak under pressure? I have a new to me '10 fxdwg and the rear brake pedal seems kinda soft. Ive bled the line twice, and recently noticed what appears to be droplets of fluid around the bleeder valve area. I don't have a cap on the valve, but don't think that would have anything to do with it possibly leaking. Ive attached a pic of area, and this is after a wash and short ride.
Any suggestions would be appreciated. Dealer charges 125 an hour here and would like to avoid that if at all possible.
Old Jun 10, 2020 | 06:55 PM
1340hog's Avatar
1340hog
First off that looks like the caliper not the master cylinder. Secondly I have to ask is the bleeder tight? If it is i'm not sure never had one do that. Take the bleeder out and make sure the caliper is not cracked around where the bleeder goes. If everything looks good then replace the bleeder.
Old Jun 10, 2020 | 06:57 PM
SmittyFXDL's Avatar
SmittyFXDL
Yes, thank you for the correction. and yes, the bleeder is tight. Ill get another one tomorrow and replace and check threads and area for cracks. Thank you.
Old Jun 10, 2020 | 09:48 PM
hardheaded's Avatar
hardheaded
Make sure there is no debris down inside where the bleeder seats.
Old Jun 10, 2020 | 10:16 PM
d_slat's Avatar
d_slat
Old Jun 12, 2020 | 09:01 AM
Max Headflow's Avatar
Max Headflow
If you bleed the brakes, what dribbled out may simply be whats over sitting between the actual valve location at the bottom and top of the bolt. Get a cover for it.
Add:
While I've not ridden one, I understand the rear brakes on later Dynas suck.
Redbeard07
Shovelhead
Apr 24, 2018 08:54 AM
Max Headflow
Mar 30, 2017 03:33 PM
roadhog0120
Oct 5, 2015 03:33 PM
GLIDEGASM
Wheels/Tires
Aug 7, 2013 07:43 AM
Chopster1200
Oct 4, 2009 10:53 AM
