Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
04 FXST Swing arm (rear fork) bearings
Old May 29, 2022 | 02:24 PM
JLOCKHART29's Avatar
JLOCKHART29
Default 04 FXST Swing arm (rear fork) bearings
OK so the shop manual says lifetime. Yea almost 20 years and 125K while I got this thing scattered I'm changing the bearings. Got shop press so that should be no problem. Only question b4 I start
pushing is the little retainer clip. For the life of me looks like it is basically an "adapter" to the bearing to set the depth. Ne bearing has it all ready installed. So just press from the inside of swing arm out and press new bearing from outside in till clip is flush with frame correct? Thinks
Old Jun 2, 2022 | 08:25 PM
JLOCKHART29
Well I can confirm they do press out from the inside and press back from the outside. Mine were almost 20 year and were shot. No grease left. I have a 12 ton shop press and I didn't think I would get them to move without it. Once they moved it was all good but never would have broke them free with all thread. (I tried)
Old Jan 5, 2023 | 07:17 PM
Iron lHorse's Avatar
Iron lHorse
I was just thinking about doing mine on a 2005 ST Deuce with 45,000 miles. After reading this thread ,seems I can go another 5 yrs .
ajames01r
Feb 20, 2020 10:24 AM
Johnnypop
The Dark Side
Sep 21, 2019 07:38 AM
98hotrodfatboy
Shovelhead
Nov 6, 2017 05:20 PM
cajun555
May 9, 2011 08:01 AM
sargek
Sep 7, 2008 09:36 AM
