Well guys, after a night of sitting, my master cylinder still full and I even left the banjo bolts and hose hang free from both front calipers and no fluid ran down.
Seems common culprit is upstream at master cylinder end. I loosened off banjo at MCyl and cycled brake lever and not much activity. Once holding thumb over outlet it does build pressure resistance and fluid follows. I reconnect outlet hose to MCyl and still nothing builds up or comes out. I did notice however that by loosening banjo at each caliper and cycling lever that you can hear and see spirts but no real flow and once securing banjo, cannot build any pressure or lever resistance. I know that my MCyl is good as it was operating perfect prior to the hose replacements and cracking the system open.
Think at this point I will resort to a pressure bleed or vacuum draw from bottom to force out and air and hopefully fill MCyl from bottom up. Once I get that far… I hope.. I can then finish off with a standard bleed at each caliper.
I’ve read a lot of posts and videos and I’m not alone with this.
And I don’t intend to keep pumping the lever 3000x to hopefully build pressure.
Its quite simple fluid engineering…but air is the culprit.
One would only assume that fluid would have gravity fed all night but that wasn’t the case.
Thanks but that was a misread.
i won’t be drawing vacuum to suck fluid down, but will charge the fluid from caliper bleed and force upwards into Mcyl….is what I meant to say. And finish off any residual bleed the conventional way once I have full fluid in calipers and hoses.
Grateful and thanks
Jim
And if you find that there is fluid throughout the system but still don't have a solid lever, THAT is when you should do the lever tie back overnight method.
^ THAT worked for me. Just zip tie your front brake lever compressed with the system closed up. Leave it sit and see what happens after a day or so.
I recently did a brake bleed on my front brakes on my 2002. NO ABS.
Tried a vacuum bleeder. Close bleed screw, pump up, get 15# vacuum, crack the bleed screw, and then air bubbles get sucked into the line. FAIL.
did old fashion method.
I would pump up brake, wrap strap around handle, crack the bleed screw ( hose into small bottle with brake fluid). out comes fluid, tighten, repeat. Did that several times to change out enough fluid on both front calipers. Started with front left caliper since it is slightly longer hose.
Pleased with results.
Your old fashioned method sounds so easy and realistic, yet just unable to build any pressure by pumping lever…or tying lever and feeding as you state. Congrats your end!
I didn't read all the replies ... Sometimes a brake bleed can be very frustrating ... I know you said your master was operating BEFORE you did your service ... Is it possible that you bottomed the master ( plunger) ? ... It has happened before ... Be careful of the mess ... Disconnect the line coming out of the master ... Hold a finer over the outlet port ... Are you sensing any pressure when you depress the lever ?
Uncle Larry,
Yes..lots of pressure almost immediately.
Yet it won’t pump the fluid down the lines. There is indeed some minimal fluid that seeps out of both caliper bleed screws but nothing significant.
oh well
