Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
2003 Fatboy wheels on 2002 FXST
Old May 13, 2008 | 06:34 PM
T4Turtle's Avatar
T4Turtle
Default 2003 Fatboy wheels on 2002 FXST
I have searched and there are similar threads but nothing I could find specific to this. I have a friend who is going to give me a good deal on her stock 2003 Fatboy wheels.
Sounds like the front wheel swap is pretty straight forward, change the fender, add spacers to movethe brake, and maybe a wheel spacer difference. I have found out from searching here that the 2003 went to a different offset rear wheel on the Fatboy. Will this be as straight forward as the front? And with this rear wheel can I run a 150? Does the offset help run a wider tire?
Just want to make sure that the 2003 Fatboy wheels are going to work, and if they are any better/wrose than an earlier Fatboy wheel.
Thanks in advance!
Terry
Old May 14, 2008 | 08:59 AM
jbt's Avatar
jbt
Default RE: 2003 Fatboy wheels on 2002 FXST
I *believe* this should be a straight bolt-on. As far as I know, there was no wheel change until the 200 tire. As far as a 150, no problem. It'll fit the wheel fine, and (barring any wierd stuff) will clear everything (belt, swing arm, etc.) with room to spare.
Old May 14, 2008 | 09:12 AM
T4Turtle's Avatar
T4Turtle
Thanks for the reply jbt!
I'll get them and see how it goes and reply back with what I had to do.
If anyone else has more specifics, please chime in.
OhioFatboy03
Dec 23, 2018 07:24 AM
WKT
Jan 15, 2018 02:02 PM
stevejt99
Feb 24, 2008 06:37 PM
michaelbarry
Sep 21, 2007 02:02 PM
michaelbarry
Sep 21, 2007 09:37 AM
