Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Help identify frame
Old Mar 7, 2010 | 11:10 AM
62 Basket case's Avatar
62 Basket case
5th Gear
Default Help identify frame
Ok here we go guys my name is Scott and I just picked up a 62 xlch that is torn apart in every nut and bolt possible. I need to know how to figure out what frame was original on this bike as I was given 2 of them and the research i have done does not show me the correct configuration for the ones that I have. so if any one can help me identify this I would love to have a correct pic of what I need. The pick from bike bandit is very close to what Ihave except that the 2 tubes in the rear for the seat do not go all the way up and through. so any help would be greatly appreciated.
Thanks Scott
Old Mar 7, 2010 | 12:44 PM
Kbore's Avatar
Kbore
Research the VINs....
Old Mar 7, 2010 | 01:10 PM
62 Basket case
5th Gear
The frames have no vin # from every where I have looked, I was even thinking of trying to turn them inside out to locate them
Old Mar 7, 2010 | 03:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I think they did put part numbers on the frames, that may be a way to trace it. If you post pics of the frames, maybe some of the Sportster experts here on the forum will be able to help identify them.
Old Mar 7, 2010 | 05:22 PM
62 Basket case
5th Gear
I have looked all over these frames with no luck locating any kind of numbers wether they be a vin # or part # that is why I am sooo confused HELP!!!!!
Old Mar 7, 2010 | 05:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Scott, try posting this over on the Sportster section of the forum, and post some pics there too. Bet someone can help you over there.
HunterAce
Nov 13, 2013 07:46 AM
Brittney Baker
Aug 10, 2013 04:30 PM
VicB
Aug 17, 2012 11:17 AM
leadtech173
Apr 30, 2010 06:37 AM
62 Basket case
Mar 8, 2010 07:54 PM
