Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Changing fork seals on a 96' Heritage
Old May 22, 2012 | 05:48 PM
Bullys FLSTN's Avatar
Bullys FLSTN
Default Changing fork seals on a 96' Heritage
Has anyone had to change the fork selas on a Heritage or Fatboy. I popped a seal the other day, so am tearing down to put new seals in. Came to the triple tree clamps , and am have a bitch of a time getting the tubes out. I pulled the clamp bolts out, have the top cap out, and the two bolts that hold the top chrome tube. Using a chisle form my air chisle in the space to spread the clamp, i am trying to spread this bast*** and i can only get the tube to slowly come down as i hit the chisle each time. Shouldn't the chisle spread the clamp enough for the tube to slide out without much resistant. I got the tubes out, but it is going to be a bitch to get them back in. What do you guys use to spread the triple tree? I watched some you-tube videos and they don't show you that part or it is a FX front end. Any help would be graetly appreciated. Bully
Old May 24, 2012 | 03:54 PM
grbrown's Avatar
grbrown
Patience! Lubrication, imagination. Don't hit anything, beat it with stealth!
Joking aside, there is no magic pill that I have found. I never tackle those sorts of job without plenty of time in hand. It will come and you will wonder what the fuss was about. Best of luck - I am about to tackle my own forks!
Old May 24, 2012 | 10:09 PM
springer3's Avatar
springer3
When you go to put it back it use a rubber hammer or a 2/4 so it wont dent or chip it!!I have found one drops out and the other wont,its just the way it is sometimes.
digthemlows
Sep 8, 2015 03:26 PM
RK El Guapo
Aug 4, 2015 10:40 AM
Bullys FLSTN
EVO
May 22, 2012 06:12 PM
sharkysw9
Mar 12, 2011 09:59 AM
heritage96
Mar 7, 2010 05:12 PM
