Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
heritage tire pressure
Old Mar 23, 2007 | 09:06 PM
thmac's Avatar
thmac
Default heritage tire pressure
2005 heritage, i keep my back tire at 32lbs /front 30lbs. friend runs 36/32 and you run ?/?. justwondering the differant air lbspeople run in their tires .
Old Mar 23, 2007 | 10:53 PM
Stevenml155's Avatar
Stevenml155
Default RE: heritage tire pressure
2006 Heritage Classic -- I run the front at 36 and the rear at 37 -- works really nice and that's what the book recomments ( 36 ). I weigh 165 lbs if that helps you or not. Bike handles like crazy, rides nice and stops great.
Old Mar 24, 2007 | 01:54 AM
tmitchellof PG's Avatar
tmitchellof PG
ORIGINAL: thmac
You should be running 36/36 solo and 36/40 with a passenger.It is a bad idea to run your tires under inflated, for their purpose and weight their carrying. I use to run the rear tire on a hard tail chopper I had under inflated. That was because I had no rear shocks and the tire was the onlygive I had.Do you have a logical reason for running your tires under inflated or don't you know what they should be set at?
Tom
Old Mar 24, 2007 | 08:49 AM
WaterHog's Avatar
WaterHog
Default RE: Tire Pressure?
I too have the same issue: I have a 06 Deuce, I keep my tires inflated according to the spec in theowners manual, however, I was told this isnt correct it should be 4psi more.
What specs do you guys follow?
Old Mar 25, 2007 | 12:10 AM
Chief101's Avatar
Chief101
My shop wrench says to go 40/40, but my 06 had some vibration in it with that. So, I went back to book specs, smooth again now.
Old Mar 25, 2007 | 04:50 PM
ChromeJunkie's Avatar
ChromeJunkie
I'm running 38-40 in both front and rear of my 06 Heritage Classic....Got 12-13K out of the rear and about 22K out of the front.
Old Apr 4, 2007 | 10:03 PM
scrawfordFLSTC's Avatar
scrawfordFLSTC
36 front / 40 rear...no problems.
Itinifni
Wheels/Tires
Feb 18, 2017 07:36 PM
Charlie Fogg
Jul 28, 2012 07:22 PM
OldBoldPilot
Feb 8, 2008 12:29 PM
hnesitd1
Jan 23, 2008 06:33 PM
sjhsc
Jan 16, 2007 01:18 AM
