FXR Models Discuss the FXR Models in here
Electrical gremlin
Old Jan 24, 2024 | 12:03 PM
Aj1's Avatar
Aj1
4th Gear
Default Electrical gremlin
Hi All,
I'm stumped with an electrical problem on my FXR. The bike has been rewired by a previous owner, whilst it works, it's a pretty shitty job. He added the newer Dyna hand controls with the left and right indicator switches, alongside the axeljoost relay to control the indicators / auto cancel etc.
So all the indicators work with the key in the first click, ACC on position. However when the bikes key is turned all the way to ign on, the front right indicator doesn't work, although the blinker light in the guage bracket does.
I've tried tracing cables and short of stripping back the loom.i can't find the issue.
Really struggling to see how that issue could arise, like something is cutting the line to the right indicator in ignition on only?
Thanks all
Old Jan 24, 2024 | 12:47 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What year bike are you working on?
What model year are the controls and switches?
We need to know this so we can look at wiring diagrams.
What is an axeljoost relay?
Old Jan 24, 2024 | 04:25 PM
johnjzjz's Avatar
johnjzjz
AXELJOOST - is when you Christmas tree the wheel spokes with multi colored bulbs and use a brush disc for the positive and the axle for ground
Old Jan 25, 2024 | 06:12 AM
Architect's Avatar
Architect
As asked, what year bike? Older bikes had a two position switch, my 1991 has one. First position is not Accessories, it is IGNITION. Everything should work, but no head light or taillight. Second position is LIGHTS, they should turn on. At some point in the late 80's the Feds made a headlight being "on" mandatory and both positions do the same thing. Good luck.
Old Jan 25, 2024 | 01:26 PM
mplecha's Avatar
mplecha
in the long run, the easiest way to fix it is to rewire the bike. you may fix one issue only to run into another later. I would use this as an opportunity to install an m-unit and never worry about the last guy's wiring again.
Old Jan 25, 2024 | 01:52 PM
RANGER73's Avatar
RANGER73
He's in the UK, they do **** different there.
Old Feb 26, 2024 | 05:13 PM
Spanners39's Avatar
Spanners39
Sounds typical FXR and is a problem I have seen a fair bit and usually caused by a shitty ground or a duff ign switch. Here in NZ most FXR's were MC bikes at some point and without exception they had a way of switching the lights off while being pursued by the Po-Po. Taking this out and its associated crappy wiring connections often fixed the issue.
I would start by taking the Axeljoost box out and proving all the connections without it and then reintroduce it and see what happens....a bit long-winded but it can be an effective diagnostic strategy.
H.sindi
Electrical/Lighting/Alarm
May 30, 2023 06:49 AM
H.sindi
May 27, 2023 06:13 PM
mean green
Jan 10, 2021 04:15 PM
Lee Talbot
Sep 21, 2020 09:32 PM
dizzy1450
May 19, 2015 03:04 PM
