FXR Models Discuss the FXR Models in here
FXR Plug Wire Keeps Popping Off Coil
Old Feb 26, 2025 | 05:32 PM
Bobby Dieken's Avatar
Bobby Dieken
Stage I
Question FXR Plug Wire Keeps Popping Off Coil
Often when I ride I will lose a lot of power and the reason is that my plug wire had come off the Coil. Obviously this ultimately stalls the engine and won't start until the plug wire has been reconnected to the coil. My question is what cause this? Is it simply crimping the end of the plug wire?
Old Feb 26, 2025 | 08:21 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Pull the boot back and look at that crimp on wire end and brass clip to coil, inspect the coil for damage. How old are the wires?
Old Feb 26, 2025 | 09:24 PM
cobra23's Avatar
cobra23
I'd buy new wires. Easy fix for the problem. Stock replacements would be fine.
Old Feb 27, 2025 | 06:26 PM
Greg55_99's Avatar
Greg55_99
Cheap and easy. Zip ties. Worked for me.
Old Mar 4, 2025 | 11:15 PM
mp's Avatar
mp
Or a new coil. I had one that broke one mounting ear off after just a few months of use. I imagine the Chinese can screw up the terminals just as bad.
Old Mar 4, 2025 | 11:42 PM
1993FXSTS's Avatar
1993FXSTS
It can be heat buildup inside the boot expanding the air and pushing the boot/cable out. Punch a small pin hole in the boot with a needle.
Old Mar 5, 2025 | 10:56 AM
Jake707's Avatar
Jake707
I had this happen to me on a road trip to AZ one time. Dam plug kept popping off the coil. The last straw was when I reached down while riding to push it back on and got zapped. Nothing like a jolt of electricity while passing through the desert in the middle of the night to wake you back up. Ran a couple zip ties to hold it on to the coil and ended up riding it like that for over a year haha. Finally replaced the wires and didn't have an issue since. Not really sure what causes it but assuming its the slip fit on the wire terminal becoming loose from vibration, heat, etc.
twincam10353
Jan 25, 2021 11:22 AM
elmo4fun
EVO
May 13, 2018 11:49 AM
thumbbuster
Nov 9, 2017 03:12 PM
SwiftyBKells
Mar 30, 2013 04:44 AM
1200efi
Ironhead
Nov 12, 2009 05:34 AM
