Fix a flat or replace a tire
Old Oct 29, 2014 | 06:27 AM
BassCatcher's Avatar
BassCatcher
Plug it up!
Old Oct 29, 2014 | 06:54 AM
dog155's Avatar
dog155
We have been plugging tires for over 50 yrs. and never once had any problems. I have seen tires worn to the canvas with plugs still in and holding air. Installed correctly they are a permanent fix.
Old Oct 29, 2014 | 07:44 AM
sixguns's Avatar
sixguns
My training has been in the repair and maintenance of HD Trucks, repairs to steering tires is not allowed. The way I see it Both my bikes tires are steering tires.
Old Oct 29, 2014 | 10:29 AM
Calavera Negra's Avatar
Calavera Negra
I once road on a tire that I had plugged 6 times. I ran it until it was low on tread. I will point out that after a while the plugs will dry out and start to leak very slightly. If you do plug it make checking your air pressure before every ride a high priority, carry an air gauge in your pocket. But like others have said the only way to not go thru any bs or insecurities is to just replace it.
Old Oct 29, 2014 | 10:50 AM
DaddyKnuck's Avatar
DaddyKnuck
Whatever you do, for God's sake make sure you use genuine Harley Davidson air!!
Old Oct 29, 2014 | 11:02 AM
WildBill_50's Avatar
WildBill_50
Originally Posted by ChickinOnaChain
I'd rather patch the inside of the tire but that's me.
+1 That is the way I would go as well.
Old Oct 29, 2014 | 11:13 AM
hvacgaspiping's Avatar
hvacgaspiping
Ride On is better than any plug. It also balances the tire and doesn`t put stress upon the hole in the rubber to possibly make the hole bigger.
Old Oct 29, 2014 | 11:25 AM
ALUCARD19's Avatar
ALUCARD19
Patch the inside and then put a tube in it this way the tube holds the air and you don't have to worry.
Old Oct 29, 2014 | 11:50 AM
Frostbite's Avatar
Frostbite
I have kinfolk that own a tire shop. One of them hits 10K+ a year on bike, and runs plugs.
It's your money, do what you want....
Old Oct 29, 2014 | 12:16 PM
deadhawg's Avatar
deadhawg
Originally Posted by NoCoLoco
I would never feel comfortable riding around on a plugged motorcycle tire. Riding is dangerous enough as it is, no need to push your luck any further. JMO
Me too. I carry a tire repair kit and would plug a tire to get home, but would put on a new tire ASAP.
And, as Frostbite said, "It's your money, do what you want...."
It also depends how and where you ride. It's not unusual for me to ride back roads out in the sticks, miles from any town, where there is no cell coverage. A plugged tire is one thing I don't want to worry about.
