Battery Tender Question
Old Nov 15, 2014 | 04:43 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by GaryM12
So under the heading of "do your frigging homework first". I took the seat off the bike and found that the pigtail has a fuse in it that was burnt. This was after I ran out and bought another tender
One 7.5a fuse later and it all works great........
Easy fix. Take the other one back.
Old Nov 16, 2014 | 10:41 AM
bill from tn's Avatar
bill from tn
Or if already opened, keep it...you will need it eventually.
If you have a garaged car, mower, snowblower, etc. that gets lots of idle time you can use it on one of those.
I have three plugged into separate vehicles as I type this. .
Old Nov 16, 2014 | 03:35 PM
DannyZ71's Avatar
DannyZ71
Sounds like your charger is shot. For the best price I've seen on a Deltran Jr., try Jafrum.
http://www.jafrum.com/Shop-By-Brand/...-PTBATTEND12JR
Old Nov 16, 2014 | 05:29 PM
cruzomatic's Avatar
cruzomatic
Glad you got it figured out. When I first began reading this thread, that was my guess, a blown fuse. I had the same symptoms on one of my tenders and that was exactly the same culprit for me, blown fuse.
Old Nov 16, 2014 | 06:55 PM
bdtaylor1979
I had an issue where the eyelet on the end of the battery tender wire where it bolts to the battery broke off where the wire attaches to it. I just cut the other part of the eyelet off and put a new one on the end of the wire. Good as new
Old Nov 17, 2014 | 07:54 AM
oct1949's Avatar
oct1949
Just use the new one on your lawnmower/snowblower....!!
Old Nov 17, 2014 | 12:22 PM
rideflhr's Avatar
rideflhr
Thanx, I just ordered another one.
Old Nov 17, 2014 | 12:35 PM
Trim Reaper's Avatar
Trim Reaper
I think you need to buy a new Harley for that extra tender. That's what I did when the same happened to me.
Old Nov 17, 2014 | 01:02 PM
dyna rider's Avatar
dyna rider
Default Battery Tender
So why did it flash on all the other batteries if you had a blown fuse on the bike battery harness ? Just curious...
BTW Thank you for your service.
Old Nov 18, 2014 | 03:31 PM
GaryM12's Avatar
GaryM12
Veteran: Canadian Forces
Thanks for the support Dynarider. I asked myself the same question after I found the problem with the pigtail on my bike. I had attached the alligator clip pigtail to the tender to check the other batteries and it has a fuse slot in it too. After I replaced the fuse in the bikes pigtail I went and looked at the alligator clip pigtail and it didnt even have a fuse in it! Now thats fixed too but I figured when I bought the tender that the fuses would be in the thing.....Live and Learn guess...
DannyZ71
Dec 1, 2015 08:29 AM
trnewman
Mar 18, 2015 09:44 PM
MJHJEA
Dec 8, 2014 11:59 AM
smathisen
Jan 2, 2013 07:18 PM
streetfighter06
Feb 14, 2011 01:14 PM
