Battery tender for multiple bikes
Old Dec 4, 2014 | 07:10 AM
airfuel's Avatar
airfuel
I have one tender that gets rotated on 5 bikes......no problem.
Old Dec 4, 2014 | 08:10 AM
gusotto's Avatar
gusotto
My dealer has a tender that they can hook up 10 bikes at once.
Needed in the showroom with so many bikes. Newer bikes are always doing a slow drain with the electronics today.
Plus the bikes aren't flying out the door, now that winter is here.
Old Dec 4, 2014 | 08:14 AM
triumph900's Avatar
triumph900
Originally Posted by 2AMGuy
There sure is!
Deltran Corporation, makes a four-bank "Battery Tender.
I have one (in additions to several single units) that I bought several years ago, but honestly, I think buying the single units may be just as economical and you have more flexibility as to where you can use them.
I have two four bank Battery Tenders. They work well.
Old Dec 4, 2014 | 09:37 AM
Aires59's Avatar
Aires59
I leave the battery fitted to the bike through the winter and just connect a battery tender for 10 or 12 hours once every month or so. Doing it this way I get a feel for what sort of condition the battery is in by what sort of charge it holds for a few weeks.
Old Dec 4, 2014 | 03:03 PM
Reindeer's Avatar
Reindeer
Exactly what I do. Except I only have 3 bikes. Each bike has a pigtail wired to the battery. I just switch the tender every week or two.
Old Dec 4, 2014 | 05:36 PM
oct1949's Avatar
oct1949
yes,, a quick search would have gotten you your answer...
Old Dec 5, 2014 | 03:21 PM
Leftcoaster's Avatar
Leftcoaster
Originally Posted by Next In Line
I was just talking to my Indy about this yesterday. He said it was a bad idea because if 1 battery dies, the charger will distribute the charging load difference to the remaining batteries. 10 batteries were killed because 1 went bad and the other 9 were overcharged.
Your indy is a dumba$$.
DO NOT LET HIM WORK ON YOUR BIKE.
Old Dec 5, 2014 | 03:28 PM
Leftcoaster
Originally Posted by katanaplanet
Is there a product which can be hooked to three or four bikes instead of putting a separate one for each bike?
You can buy either two or four single battery tenders for less that the two or four bank units. And the H-D units are simply Deltran tenders with orange labels (except that they cost even more than the green label units).
Old Dec 6, 2014 | 06:59 AM
wastedranger's Avatar
wastedranger
This is incorrect info on newer units. We will use a 2 bank 10 amp charger for example. The unit will divide the amps equally between batteries until fully charged. In the event one battery fully charges first the unit will put it in float mode. Then it will give the uncharged battery the full 10 amps to bring it up to full. Once charged it will then float both batteries. Unit will then monitor battery conditions. Then it will repeat process over and over to maintain fully charged batteries. The only downside to multi banks is usually it takes a little longer to fully charge multi batteries. Unless you pony up big bucks for higher amp units. But for storage this isn't an issue. Most new units even have lights to tell you if there is a fault. These are the way to go if you have multi charging needs in tight quarters. You only need one outlet. Otherwise I say use single ones. I have experience using both types.
FurryOne
Electrical/Lighting/Alarm
Jan 24, 2020 07:33 PM
Derf_
Apr 20, 2017 06:41 PM
Tom Hudson
Feb 21, 2012 09:35 AM
capnez
Jan 24, 2012 08:36 PM
strtarrow
Aug 17, 2011 07:13 AM
