Well here's a fun one...missing fork stem nut
Old Mar 1, 2015 | 01:28 PM
YeOldeStonecat's Avatar
YeOldeStonecat
Originally Posted by Stiggy
The pinch bolts would keep the top tree in place, but with no preload on the bearings I'm surprised that you couldn't feel it (maybe even hear it, on bumps.)
I'm guessing that you're a gentle rider.
She had a pretty bad chatter when approaching stop signs/lights....when applying from brake. Always chalked that up to the funky banana caliper up front, and/or bad front axle bushings in the bottom forks, 'n old blown seals in front forks. As I replaced those bit by bit last year...got a little better but never went fully away. Now I know. No...I push her hard.
Old Mar 1, 2015 | 02:35 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by YeOldeStonecat
Just came back from Lowes to pickup another benzie torch....so I can put some heat on it. And a few new drill bits. Heading back into garage in a few.
Trick is drill that puppy centered & square so go slow and check the angle best you can. If you do manage to drill through the bolt completely and there's an air pocket give a couple squirts of WD-40 or preferably Kroil and let it sit and soak a while before you get busy with the easy out.
Check for that star nut under that upper tree, gonna look something like item #5 in the picture in this thread.
https://www.hdforums.com/forum/dyna-...aring-kit.html
Old Mar 1, 2015 | 03:01 PM
YeOldeStonecat
Thanks for the tips...
Yup I see that start nut there. So when the upper fork tubes were in there and those top bolts tightened in from the top-o-the-tree...that was holdin' her together OK I suppose.
Whelp I'm not one for patience with drilling...went in a little off center, couldn't get to center again. The Napa ez-outs failed. The Lowes spin outs did more damage than anything...ate into the opening a bit on the head. Doubt I'll be able to hand guide a larger drill bit in there and keep it centered right..it's gonna walk off center and follow that incorrect 7/64 hole I drilled...and be eating into threads on the head. 'fraid it's better to just pull the tanks 'n rocker box 'n head and take her to my buddies machine shop.
Old Mar 1, 2015 | 03:56 PM
TwiZted Biker
Smart move on the head repair I can tell you all kinda horror stories about buggered up exhaust bolts I've dealt with over the years. If it does go a little sideways on you and the hole gets damaged it's not a major aw **** and you don't have to weld and redrill things. I use whats called a step stud for that kinda repair. There's enough meat you tap the hole to 3/8" and install a 2 size stud instead , stronger and holds the pipe better.
Far as the front end goes sounds like you are missing the top nut but look at the bright side with the star nut in there you now know the head bearing and races aren't wiped out from running loose .
If you don't have one please pick up a torque adapter for the head bolts and a decent inch lbs torque wrench for the rocker boxes . Use the metal/silicon gaskets when you redo her not the old style paper ones . Any issues finding some pm me I'll send you a set. Amazon has the adapters, the head bolts are 9/16" unless somebody put in the 12 point bolts then those are 7/16" if I remember right.
Old Mar 1, 2015 | 09:08 PM
Crashone's Avatar
Crashone
Have you tried using a fine nail set or small punch to try and tap the broken bolt counterclockwise?
Old Mar 3, 2015 | 06:10 AM
YeOldeStonecat
Yeah one of my buds has those offset wrenches to get to those difficult bolts, and the mini adapter for the torque wrench. We had pulled the heads off 2x summers ago shortly after I got it, as the tops (esp the rear rocker box) were leaking bad. Had put James gaskets in there...they've worked well. Will get either those again, or Cometics.
Thanks for the tip of putting in a stud...may do that...actually may pull rear head and stud that one too...I like that idea.
Old Mar 3, 2015 | 03:42 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Evo's have studs, and it works well.
Old Mar 3, 2015 | 04:20 PM
YeOldeStonecat
I'll give that a shot before I pull the console 'n tanks 'n rocker boxes 'n heads again....worth a shot. Dunno how much side leverage I can get with the frame down-tubes to each side....plus the top of the sheared bolt is like a sixteenth of an inch recessed in the hole. But worth a few whacks.
Old Mar 3, 2015 | 05:34 PM
Imold's Avatar
Imold
I've watched far better welders than me weld an appropriately sized rod or bolt onto the broken stud (yes, even broke off flush ones) and then turn them right out - the welding gets the broken piece hot enough to melt any loctite, and even breaks rusty ones loose. If you know a really good welder (mig, not stick!) might be worth a try; wouldn't risk more damage with drilling. You'd have a nice straight hole to drill/tap for a stud if you still wanted to. What could go wrong - if it didn't come out that way, you'd have to grind the end flush again to continue drilling. Haven't seen that happen yet. Used to to have very experienced welders do that with expensive aircraft parts, didn't want to chance messing up parts in the 10's of 1000's of dollars - or more.
Old Mar 3, 2015 | 07:53 PM
tmanbuckhunter
For the love of GOD no MIG/squirt gun/burglar bar **** on your heads... please. TIG and that is it.
