FLHX head light ....
Old Apr 9, 2015 | 07:57 PM
rydahog's Avatar
rydahog
Default FLHX head light ....
2011 FLHX replacement head light needed,,something not crazy expensive..any suggestions appreciated. Mine has some weird interior swirling fog look? no cracks visable,,but i think its stopping some light output at night. thanks.
Old Apr 9, 2015 | 08:40 PM
SSI Dog's Avatar
SSI Dog
Two options that won't break the bank: truck lite LED or a HID (high intensity discharge). If you go the HID route, choose the 35 watt and don't go over the 6000k light or you'll lose the clear light. For HIDs, check out socalmoto gear, but there are many more vendors. I've got HIDs for low and hi beam and you'll definitely be seen in the day and spread the light at night. The stock headlight sucks and is about as useful as holding out a flashlight at night.
Old Apr 9, 2015 | 08:43 PM
DannyZ71's Avatar
DannyZ71
Or, you could pull the headlight out, remove the bulb, and swish some alcohol/water (or is it water/vinegar?) around in there to clean it out. Use a compressor to blow dry it out. Then put an aftermarket bulb in it.
Old Apr 9, 2015 | 08:47 PM
flhxkiller's Avatar
flhxkiller
yeah that
Old Apr 10, 2015 | 09:53 AM
Steeltoe's Avatar
Steeltoe
What Danny said. Use denatured alcohol, pour some in the headlight, drop in a small piece of paper towel. Then swirl it around a bit, dump it and let it dry or blow out with compressed air.
senna
Aug 30, 2013 02:33 PM
AmericanMuscle
Dec 4, 2012 06:45 PM
Swamp-Rat
Oct 31, 2010 08:25 PM
yso191
Nov 10, 2009 03:15 PM
CaptnAl
Aug 20, 2007 10:25 AM
