help
Old May 6, 2015 | 09:56 PM
warren827's Avatar
warren827
Stage II
Default help
Can somebody tell me how to remove the bolts in the end of the swing arm so the axle can be pulled so the rear tire can be removed?
The bolts are to adjust the belt.
Old May 6, 2015 | 10:15 PM
jtarter's Avatar
jtarter
No need to remove the bolts. Just loosen them up push the wheel forward and rotate the belt off of the sprocket. Then pull the axle out.
Old May 6, 2015 | 10:33 PM
RHPAW's Avatar
RHPAW
Nobody can tell you that. You have to pull the axle first, because it goes through the other end of those bolts.
Old May 7, 2015 | 08:23 AM
an Uncouth Barbarian's Avatar
You need a shop manual.
Old May 7, 2015 | 10:31 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old May 7, 2015 | 03:02 PM
Coastal CVO's Avatar
Coastal CVO
I was thinking he might need a shop Period...
That was mean, I apologize.
drspencer
Jun 19, 2023 07:57 AM
Sarah93003
Jun 16, 2017 08:14 AM
mi2az
Dec 7, 2011 06:00 PM
scarroll1371
Jan 23, 2011 02:35 AM
harley_jeff
Aug 20, 2009 10:20 AM
