Front fork slider plug position
Old May 10, 2015 | 03:19 PM
rphillips's Avatar
rphillips
Default Front fork slider plug position
About two months ago I rebuilt the front forks on my 98 Fat Boy and have been riding since. The other day I noticed fluid leaking out of the left fork drain plug so I tightened it. After riding again I noticed more fluid so I decided to put a new copper washer while doing so I noticed my problem. When I was adding the fluid I noticed that when I rebuilt the forks I positioned the slider tube plug incorrectly. The manual says to make sure that one of the flats on the plug is facing towards the inside of the fork, mine are positioned forward and aft. Will it really make a difference if I leave them the way I have them? If I have to re position them I was figuring on leaving the wheel on and loosening the fork stem bracket pinch bolt and cap nut one at a time and then turn fork tube to the correct position is that OK, to me its seems so?
Last edited by rphillips; May 10, 2015 at 03:24 PM. Reason: Incorrect discription of part
Old May 11, 2015 | 08:57 AM
hardheaded's Avatar
hardheaded
that has no bearing on the drain plug leaking. and yes the top plugs should be flats to the outside. the reason for this is so the tree cover bolts can go in and make contact with the plug.
Old May 11, 2015 | 12:07 PM
rphillips's Avatar
rphillips
I know that it has no bearing on the drain plug leaking I just gave more information then needed. I went ahead and repositioned the slider tubes so the plug flats are in the correct position. After thinking about it I surmised that it might give the top of the tube a little more strength that way, it is moot now that I corrected it. Thanks for your reply
wulffe
EVO
11
Sep 5, 2024 05:27 PM
harley0711
Sep 22, 2015 09:50 PM
v0odoo98
May 27, 2014 07:46 AM
sanman4ever
Feb 21, 2013 10:08 PM
dawg
Oct 26, 2008 07:14 PM
