Bike overheated; embarrasing
Old Jun 2, 2015 | 08:53 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Bike overheats you'll know it they start acting real ignorant , sputtering, stalling and making noises an air cooled engine never should. Dealt with a number of fried harley engines back in my midwest days, worse case is pistons start to seize then let go and skirts break and you throw a rod. What usually happens is scores hell of the cylinders walls and the piston slap starts, weakens rings were they won't seal and valve guides gall up, seen more than a few get so bad the guides break loose in the heads.
This was all shovel's & evo's which run cooler than these new big inch ball cookers you guys ride.
Yes , but metallurgy has come leaps and bounds since those days, along with oil technology, kinda apples and oranges there, but you are right as to what can happen to any severely overheated motor.
one of the things that happens to BMW car motors when badly over heated, they dont blow head gaskets, they pull the threads right out of the block via the head bolts. quite a big deal time-serting 16 holes!
Old Jun 2, 2015 | 08:55 PM
Riptide1's Avatar
Riptide1
As Charley suggested, check for codes.
Then add a good dual fanned oil cooler to start.
I was headed south last week on I-75 interstate here in Florida and a lumber truck decided to smash into another vehicle wherefore scattering 2x4's everywhere.
15 mile backup.
Once my jeans started smoldering I said the hell with this and headed for the side of the road and proceeded towards the kaos which caused the traffic jamb.
Turned a 1 hour back up delay into a 5 minute delay.
Old Jun 2, 2015 | 09:09 PM
upflying's Avatar
upflying
Legal lane splitting will prevent overheating.
Old Jun 2, 2015 | 09:10 PM
TwiZted Biker's Avatar
TwiZted Biker
I strongly suspect heat is one of the major reasons the twin cams run the looser engine tolerances than the old ones did so things have room to swell and move a bit. Couldn't believe how hot some of the twinkies are when buddie stop by and we aren't a hot area. Early evo's were prone to stretching the cylinder studs and pulling the threads from the cases when they overheated badly, most times the heads would warp and the gaskets let go first.
Old Jun 2, 2015 | 09:18 PM
brutalbrad's Avatar
brutalbrad
https://www.harley-davidson.com/app-...NG/file-6.html
Air-cooled engines require air movement over the cylinders and heads to maintain proper operating temperature. Extended periods of idling or parade duty can overheat the engine, resulting in serious engine damage. (00178a)
Old Jun 2, 2015 | 09:21 PM
JustDave13's Avatar
JustDave13
That'll keep the MoCo out of the court room
Old Jun 2, 2015 | 09:22 PM
harleycharlie1992
they are some noisy sob's when they start up, aren't they?!
Old Jun 2, 2015 | 09:36 PM
lh4x4's Avatar
lh4x4
BS. HD runs tests at their facility in the Arizona desert leased from the Chrysler Proving Grounds there. The test involves letting the engine idle for a full twenty four hours. They never failed.
"Overheating" is when an engine is damaged such as warped heads or valves. So how much did the repair cost you?
I was caught in a traffic tie up on the interstate down south during a declared tropical heat wave in 2011. The traffic was stop and go for over an hour. The 2010 Ultra went into the rear cylinder cut out mode each time we stopped. No damage at all.
The following year on a trip through Death Valley during a summer day of temps of 115 to 120 degrees neither my son's TC 88 or my TC96 suffered any damage.
This was the destination during the heat wave.
So OP just man up and admit that you couldn't take the heat as well as your HD did.
Old Jun 2, 2015 | 09:55 PM
Love Jugs's Avatar
Love Jugs
Former Sponsor
Default more than an embarrassment it's a problem. There's one REAL solution
Originally Posted by slowrollin
On vacation in Miami with a bunch of guys in my club and my bike overheated in traffic. She wouldn't start up until in cooled down. Took about 15 minutes. Embarrasing cause I'm the only one on a Harley, and the only one who overheated. To be fair, we were in bumper to bumper traffic for about an hour in the Florida heat, so it's not the bike's fault. Wondering if the 2014 or 2015s with the liquid cooled heads would still have this problem? Don't want this to happen again.
Hot Harley - Problem Solved. I don't have to say a word. Check out what the industry is saying about Love Jugs here, http://love-jugs.com/experts-saying/
Old Jun 2, 2015 | 10:06 PM
Riptide1's Avatar
Riptide1
So, has anybody installed the Love Jugs on their current or past scooter?
Any real word experience here?
