I need help quick! All the sudden I'm having problems with making sharp right turns. I've never had the trouble before. Just started going wide every time. Went out the last 2 days for parking lot practice. No progress at all. Thought I was going too fast. Even less 10 mph I can't turn right and go through 1 parking space without crossing into the other. It has gotten in my head some way and can't get it out. This is very unsafe. I'm nervous about turning in my subdivision. Worried I'll swing wide and hit someone. Ideas?
Should you consider seeing a doc? This seems very odd.
Seeing as you're now nervous when making right handers are you tensing up your right shoulder? Meaning are you pulling your shoulder up towards your ear? If you are then you'll never be able to make that tight right turn. You have to relax, brake before the turn, then (gently) accelerate thru the turn. https://search.yahoo.com/yhs/search?...&hsimp=yhs-004
