tappet noise
Old Jul 10, 2015 | 01:40 PM
ngshop's Avatar
ngshop
tmanbuckhunter
'"Pre-load is a side effect of adjusting your pushrods properly" or lifter adjustment (pre-load) as you like to call it, is a side effect of pushrod adjustment.
I think you are splitting hairs... your hairs.
PS measure the height of a lifter with no pre-load and then with pre-load. Then let me know if there is a difference in height/adjustment.
Old Jul 10, 2015 | 02:37 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Originally Posted by ngshop
tmanbuckhunter
Lifter height stays the same, unless you want to split hairs and call the socket/seat the actual lifter which it's not.
Please explain how you will change the height of this lifter without removing metal. You cant.
Old Jul 10, 2015 | 02:54 PM
frontiercat's Avatar
frontiercat
My brand spankin' new Low Rider makes a bit more overhead noise than I am completely comfortable with, but it hasn't kicked any parts out yet.
And only solid (read: non-hydraulic) lifters can be adjusted (set variably) via adjustable push tubes.
Old Jul 10, 2015 | 03:04 PM
ngshop's Avatar
ngshop
tmanbuckhunter
Nice picture of the tappet, is there a lifter inside?
Old Jul 10, 2015 | 03:12 PM
soft 02's Avatar
soft 02
Grind a little bit off the wheel! Sheesh....
Old Jul 10, 2015 | 04:02 PM
tmanbuckhunter
tmanbuckhunter
Oh geeze, lifter/tappet are the same damn things, just different names. I'm done.
Yeah, that'll do it. "Variable" valve timing.
Old Jul 10, 2015 | 04:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
On a recent trip to York/Lancaster area, (800+ miles from home) we had a day of highway speed and my lifters were just a singing. Using the HD gauge in the inner fairing oil pressure probably at or near 25 psi. The next day, while traveling freeways (actually Fee turnpike) the lifters were just like normal, oil pressure at 32 psi. Just a hit or miss on noise. Doesn't seem right one has to replace with a better lifter when there's only 8500 miles on the originals.
Old Jul 10, 2015 | 04:15 PM
ngshop's Avatar
ngshop
Looks like we will both just give up! I come from the old school of panheads and shovelheads and my memories fade. A couple of pics.
Attached Thumbnails tappet noise-lifter-tappet-assy.jpg   tappet noise-lifter.jpg
Old Jul 10, 2015 | 04:34 PM
frontiercat
To the OP:
When you say rebuilt, what exactly was done to the engine?
Did you have any machine work done on the heads?
What was the reason for the rebuild? Some sort of failure?
What parts were replaced? Cams, lifters, etc?
Old Jul 10, 2015 | 04:38 PM
soft 02's Avatar
soft 02
Whell if they put the Mexican HD lifter in there they could have gone bad. HD lifters aint what they used to be.
