A "good enough" ground?
Old Aug 3, 2015 | 03:41 PM
dyna rider's Avatar
dyna rider
Default Battery to USB
Take a look at this...
http://www.batterytender.com/Accesso...arger-QDC.html
This and a long USB cable will get you there.
Old Aug 3, 2015 | 04:02 PM
dyna rider's Avatar
dyna rider
Default Power Port
I have a Kuryakyn handlebar power port on my smaller bike and have one of these to plug into it if need be.
http://www.kuryakyn.com/categories.aspx?s=power%20port
http://www.walmart.com/ip/4-Port-USB...arger/44570961
Old Aug 3, 2015 | 07:24 PM
Ride my Seesaw's Avatar
Ride my Seesaw
Originally Posted by JohnK-NJ
I wanted to hardwire a USB adapter by my handlebars. I found power from a spare yellow wire coming from headlight. Do you think I could use a ground bolted to the forks?
Your ground at the forks sounds fine for a low current USB charger. I wouldn't use the power line going to the headlight though. If for whatever reason your USB charger fails it could take out the headlight's fuse at the most inopportune time. Run an independent wire to the battery's positive terminal with a 5 amp fuse near the terminal.
Old Aug 3, 2015 | 10:11 PM
Ironcleveland's Avatar
Ironcleveland
No. As far as I know without looking up the diagrams, the forks are not directly grounded to the frame. The frame is directly grounded to the battery. So current is going to flow through the steering neck bearings back to the frame. It's not a large amount, so most likely won't cause any noticeable problems. But it's not good for them and might result in some connectivity issues for your charger as well.
grbrown
Apr 28, 2016 07:43 AM
bmfakler
Ironhead
Aug 4, 2015 09:17 PM
marine_hm@hotmail.com
Jun 21, 2012 08:43 AM
OnTheFence
Audio Systems
Jan 28, 2011 05:37 PM
NORTHWESTJIM
Feb 25, 2010 06:38 PM
