another caveat..... if you ride the bike 10-15 miles before change, you will make sure any and all debris or contaminants are in suspension....that is fully mixed with the oil. also condensation will be burnt off or absorbed in the oil. Then when you put fresh fluid in, you know you got all the crap out.
That right there is the reason for draining hot. Best practice is to plan ahead, drain after your last ride. I don't ride much on weekends, so Friday night when I get home I pop the plugs and fill it up the next day.
+1 with Spartaden, drain while hot, it removes all the suspended contaniments, won't go into detail about getting your bike upright off the jiffy stand while draining.
This is the #1 reason to run the bike in gear to warm the fluid and get the debris suspended and allow it to drain. Thumbs up!
With my Softail I change the engine oil hot to make sure as much oil is in the tank as possible. Primary and transmission I don't worry about, as by the time I get to doing them during a service, they've cooled off again. I just open the plug and let them drain while I'm doing something else.
I have 198,000 miles on the original transmission, so if I was doing it wrong, I'd know it by now.
I drain mine hot enough to be uncomfortable touching the plug with the bike on a jack so it's level. That's the only way I found an entire quart fills it exactly to the top of the hashmarks. Did it in winter once with a brief warm-up and couldn't get 3/4 of a quart in there. It certainly has to do with viscosity of different fluids- I use Red line which is really thick when it's cold.
