Dynojet PCV Performance Increases?
Old Sep 3, 2015 | 02:40 PM
DINSDALE's Avatar
DINSDALE
5th Gear
Default Dynojet PCV Performance Increases?
Hi all
I am planning to fit a Dynojet V Performance Commander to my 2009 Fat Bob
What BHP increases can I expect to gain?
And what other benefits, if any, will result from the upgrade also?
I have already fitted Vance Hines pipes and Screeming Eagle breathers so hopefully the PC fitting will be the icing on the cake?
Thanks
Mike
Old Sep 3, 2015 | 04:04 PM
oc1014's Avatar
oc1014
I would suggest taking a look at the Fuel Moto website or there face book site, they have a ton of run sheets posted. Should give you a good idea. The best thing is of course your bike will run like it should have from the factory, thanks EPA.
Old Sep 3, 2015 | 05:49 PM
JohnMn's Avatar
JohnMn
I'm not sure about a V Performance Commander,,
But I installed a Power Commander V(5) from Fuelmoto with a pre-loaded map for my 09 Superglide after installing V&H Bigshots and a Screaming Eagle Stage1 air intake.
While the increase isn't what folks brag about when doing big upgrades and/or have the bike dyno tuned after all that stuff is installed,, there was a significant difference in preformance.
I could feel more low end torque/power with much improved acceleration and throttle response,,
I don't have fact sheets from a dyno tune,, but what you plan on doing will give you a different and improved feel to your bike.
Be sure to make your PCV purchase from Fuelmoto!! What Jaimie can do for you and the support they have IS worth the extra few bucks!!
p.s. Dynojet and Fuelmoto are "partnered" companies,, they work with each other,,
Old Sep 4, 2015 | 05:35 PM
RK4ME's Avatar
RK4ME
Originally Posted by DINSDALE
Hi all
Thanks
Mike
In my experience with doing the Stage 1 mod's on my '04 Road King, the Power Commander is the "cake", and the slip-ons and the Screamin' Eagle A/C are the icing.
+1 on FuelMoto
decencyxdefied
Feb 5, 2015 01:10 PM
zwildman
Jan 11, 2013 07:37 PM
myred55
Oct 17, 2012 05:58 AM
Teleman444
Sep 2, 2012 07:12 AM
D.Bob
Mar 28, 2012 03:25 PM
