You guy's just keep in mind that those modules generate their own heat when used,, they get hot.
Not a big deal, it's not a fire hazard,, but they wear out.
I know guy's that are constantly touching brake levers just to give the guy behind a "flash" to back off or just for an extra "see me" nudge.
They complain because the module doesn't last long,, just use your brakes like normal.
Cant have enough lights in the back. You got alot of them.
Harley has some new filler lights for the saddle bag supports that I'm thinking about getting. I replaced the taillight with the Harley LED taillight because it matches everything else. Their filler lights match also. You're right...you can't have too many lights.
I have this Module and I set it to flash 5 Times and then to stay "On" continuously until I release and re-apply the brakes at which time it'll repeat this sequence. However I have the Module on mine set to flash the Main Center Brake and Running Light. My Trunk and Saddle Bag Lights function normally.
I added the Harley Electra Glo LED Saddlebag lights, P/N 67800241, which the OP has on his bike, and have had many positive comments on them. When I first saw them when following other bikes that had them I was really impressed by how much they increased the viability of the bike. If the price on the Harley Filler Lights, P/N 90200873, were a bit less I'd add them as well.
I have the Triple-Play and use the Blaster X pattern, The strobe flashes for about 3.5 seconds then solid. It's very attention getting. Also just added a laser light that shines a line on the ground a few feet behind me.
I just installed the CD Triple Play on my 15 CVO. It works great on the taillight and turn signals. It does nothing for the center tour pack brake light. Do I have to have a separate module for the tour pack brake light ?
Sorry, just saw your question. The one I bought is strictly for the LED tour pack lights on '14 and up bikes.
HD LED Tour Pak GEN2 Magic Brake Light Flasher
Installation Instructions
( This unit will strobe the Tour Pak Brake Light, can be used with or without MAGIC-STROBES-BCM)
I got it on Amazon. From Ami Lee Chow or something like that. There are hundreds of em with lots of different patterns, Skulls,Stars, etc......The one I got is metal not plastic and only shines a line on the ground.Very bright at night. In fog or rain you can see the whole triangle from the projector to the ground. The higher up you mount it the wider the beam. Mine is under the tag. Oh it was only $15.00
BRB with a photo.
It angles when bike leans, When bike is straight up it's squared perpendicular,
Reason: added photo
BRB with a photo.
That is innovative right there. I am sure it freaks cagers out.
BRB with a photo.
