With the help of everyone in this forum I rebuilt the forks and calipers on my new to me 1996 fatboy, thank you !
So after putting everything back together I have noticed my forks are not aligned meaning my handlebar are slightly (I would say probably a 6°) turned to the right when rifing straight
What I did wrong was with the excitement of putting everything back together I did not tighten everything slowly quarter turn at a time I tightened one side and then tighten the other side all the way and I am guessing that's where I went wrong .
So my question is I don't have anyone to help me and I don't know a way of just lifting the back end of the fat boy up... how do I align everything up and tighten it down does anybody have any tricks obviously I can't do it while on a side stand
I like to get the front end up off the ground and everything just snug with top of fork tubes just above top tree. Install and torque axle in the lower legs to align the legs. Then sight across front or rear of tubes to confirm top and bottom trees are aligned before tightening the tree clamp bolts. When you are finished you should see both fork tubes are aligned, I'll bet right now they are not.
That's a good bet! They are not ok i have lift but it just lifts the whole bike, can I do this with both front and back off ground,, I was going to use the bouncing the forks method so let everything fall into place.
I could tell you how I install motorcycle forks, but isn't that covered in your shop manual?
I looked at the section on how to take them off and put them back on I don't remember seeing anything about alignment maybe it's near the end I will doublecheck
loosening the tree clamps and tweaking the bars will change the alignment of the fork tubes and can be done on the lift with both wheels off the ground but you will need to have somebody hold the front wheel straight while you tweak.
Don't loosen the fork caps. There's a lot of pressure on them from the fork springs, and they don't have anything to do with alignment.
The axle should align the fork tubes to each other laterally. Once you have that installed, move each tube up or down in the triple trees until they're at the height you want, and then check (preferably with a Vernier caliper, but a machinist's ruler will work) the height of each one to verify they're the same. Tighten pinch bolts and recheck height.
