Helmet speaker installation
Old Jun 10, 2016 | 06:36 PM
dlporter's Avatar
dlporter
Default Helmet speaker installation
I have a scala rider packtalk on the way, but have a question about installing the speakers. I wear a HJC RPHA ST full face helmet. This helmet does not have speaker cutouts in the eps liner. Question for those of you who have installed these in the past; do you install the speakers behind the comfort liner in the ear pockets, or do you install them on the liner such that the speakers will be between my ears and the liner?
Old Jun 10, 2016 | 06:40 PM
Ibfuelish's Avatar
Ibfuelish
Theres probably a correct answer to this, but put them where you can hear them. Often times you might have to get some velcro to attach them between the shell and the inner ear hole cut outs.
Old Jun 10, 2016 | 06:59 PM
grumble's Avatar
grumble
and believe, 1/4" in positioning can make *all* the difference in the world.
Old Jun 10, 2016 | 07:08 PM
Mike Lawless's Avatar
Mike Lawless
When I first tried to put speakers in my modular helmet, the recesses were too high and too far back. The Sena speakers are maybe 5/16" thick, and even in the recesses, they pressed against my skull and pinched the tops of my ears. It would hurt after a while. Plus it was hard to hear.
My Arai helmet has the recesses perfectly placed. Because they are right over my ears, the sound is much better and they don't press against my head.
Under the liner is where I put 'em too.
If your helmet doesn't have recesses, I hope it's got enough padding that the earphones can sit inside. Lots of differences in the helmets I have. You'll just have to experiment with placement.
Old Jun 10, 2016 | 07:20 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I put ours in the ear pockets, ON TOP on the liner.
Old Jun 10, 2016 | 07:36 PM
dgoodbmw's Avatar
dgoodbmw
Default speakers
A hot soldering gun will melt the foam anywhere you need it and as deep as you need and allow the speakers to not create a pressure on your ears.
Old Jun 11, 2016 | 12:36 AM
rufasim's Avatar
rufasim
My Shoei came with spaces for speakers. Can't you mount them to the hard shell and cut the liner around them?
Skyking75
Aug 1, 2017 07:10 AM
Hotrodz_n_Harleyz
Nov 20, 2013 10:44 PM
keno
Nov 26, 2010 07:45 PM
snakeinthegrass
Apr 15, 2009 11:46 AM
questor
Apr 25, 2008 02:47 AM
