Fuel problem?
Old Jul 3, 2016 | 03:47 PM
PPBART's Avatar
PPBART
Default Fuel problem?
My '07 Deluxe has been running just fine. However, yesterday I went for a ride with a couple of friends, nothing special or challenging. I was coming home, perhaps 2-3 miles from home, when the bike started really running rough -- coughing, popping, almost choking down, then reving back to almost normal before repeating the problem. I was able to keep it running to get home. First thing that came to mind was maybe bad gas? (I had got gas -- 2.4 gallons to be precise -- about an hour earlier). I drained the tank, then refilled it with 4 gallons of premium from a trusted station. I tried running the bike in hopes of -- if the problem was bad gas -- burning the bad gas out. Didn't seem to help much.
This morning, I ran the bike some more, total of about 40 miles since refreshing the tank. Still running really rough!
Any ideas of what might be going on here?
Old Jul 3, 2016 | 05:15 PM
grumble's Avatar
grumble
Fuel filter?
Old Jul 3, 2016 | 05:36 PM
bdtaylor1979's Avatar
bdtaylor1979
I had the same issue on a dyna I had and it ended up being one of the fuel lines inside the tank.
Old Jul 3, 2016 | 10:11 PM
Keithhu's Avatar
Keithhu
Pin hole in fuel line? Fairly common problem - how low was your fuel. When this happens, if memory serves from the threads I've read, bike runs fine until about 1/2 tank.
https://www.google.com/search?q=hole...hrome&ie=UTF-8
Also, any codes?
Old Jul 3, 2016 | 10:59 PM
bdtaylor1979
Also, any codes?
Mine ended up being a oring on one of the fuel lines according to the dealer. But it was covered under warranty.
Old Jul 4, 2016 | 12:07 AM
Next In Line's Avatar
Next In Line
Do a fuel pressure test.
Old Jul 4, 2016 | 12:13 AM
SIDECAR BOB's Avatar
SIDECAR BOB
might want to check loose plug wires or bad plug wire also spark plugs condition . also make sure your battery connections are clean and tight no codes showing ?
also check to make sure the quick disconnect on the tank/fuel line is seated and tight, there has been instances of them wearing and causing fuel supply issues.
Old Jul 4, 2016 | 12:14 AM
klc997's Avatar
klc997
Sounds like fuel pressure regulator. Pressure test will confirm.
Old Jul 4, 2016 | 12:43 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Check the little rubber cap that sits on top of the throttle body. If it has cracked or come off completely your bike will run like you described.
Old Jul 4, 2016 | 01:02 AM
chief08's Avatar
chief08
yes that's the first thing I would do.
