Houston area led lighting for bike
Old Aug 11, 2016 | 08:09 PM
SDozier's Avatar
SDozier
Cool Houston area led lighting for bike
Anyone know where I can get my led under bike lighting repaired in the Houston / Humble / Woodlands area? I looked in yellow pages with no luck.
Recommendations,
SD
Old Aug 13, 2016 | 11:04 PM
thor05deluxe's Avatar
thor05deluxe
It's a pretty simple task to put led's on a bike. If you spent more than an hour on it I'd be surprised. Check YouTube out and just follow the old wiring and replace.
Or wait till the lonestar rally this fall and head down to get it done there.
Old Aug 14, 2016 | 08:59 AM
SDozier's Avatar
SDozier
I need repair work done on the LED system that is in place. I accidentally split a wire that leads to one part of the lighting and now the entire thing does not work. I have spliced with a wire nut but it still does not work. I am thinking it has to be soldered and shrink wrapped in order to work. I can wait to Lone Star Rally as I rarely use the LED's but it is on the bike and I would like it to operate properly. Thanks, did not think about the rally options.
Old Aug 14, 2016 | 10:06 AM
hungry horse's Avatar
hungry horse
I haven't lived in that area in several years, but when I lived in Humble, there was a good indie shop just north of the river at POP's Ice House.......Not even sure if it's still there, but you can check.
Old Aug 14, 2016 | 04:46 PM
Bestrafen's Avatar
Bestrafen
It's very simple wiring. If it's single color led's, then there is only 2 wires, Positive, and negative. Positive wire will be fused, and have a switch. Negative will go to chassis ground, or negative terminal on your battery.
If they are RGB led's,(color changing)there will be 3 or 4 wires. 2 of which will be positive, and negative.
Simply put, go buy or make a cheap test light. Check first that your negative(ground) is connected. Now, take your test light and follow your positive wire from the battery, to the fuse, and through the switch. Where it doesn't light up is your problem.
Old Aug 14, 2016 | 06:17 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Recommendations,
SD
If you need them repaired, go to most any crotch rocket shop...I see a lot of those bikes lit up like Christmas trees.
mgordyan
Apr 1, 2012 04:16 PM
cjackermann
Jun 18, 2011 02:28 PM
cjackermann
Jun 18, 2011 12:01 PM
JCTulsa
Electrical/Lighting/Alarm
Oct 28, 2008 11:57 AM
Born2cure
May 4, 2008 03:32 AM
