FXR or Softail
Old Aug 20, 2016 | 06:07 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Soft tail because that's all I've had. No ugly shocks showing on the side.
Old Aug 20, 2016 | 06:18 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Watch out for a Softail in that date range. It could be one of the early solid mounted EVO non balanced engines. Unless you like that vibration filling.
Old Aug 20, 2016 | 06:29 PM
TwiZted Biker's Avatar
TwiZted Biker
All softtails were that way till the twinkie models , early slop tails had issues like a mix and match of shovel parts still and really bad shocks on the rear
upflying's Avatar
upflying
FXR's were the best HD chassis ever made.
I ride a Dyna because it is as close as you can get to a FXR.
Old Aug 20, 2016 | 08:52 PM
Greezey Rider's Avatar
Greezey Rider
Buy the FXR...Softails are JUNK, sorriest bike Harley has ever built.
Old Aug 20, 2016 | 10:36 PM
sharkey's Avatar
sharkey
FXR for long term value, smoothness & handling. Ugly stock 80's style though. JMO
Shovel would be real intersting, but more maintenance...
Old Aug 20, 2016 | 10:51 PM
Fred Halstead's Avatar
Fred Halstead
So would I need to stay with 1998 or newer if I went with a softail to be in a twin?
Old Aug 20, 2016 | 10:55 PM
Bingee's Avatar
Bingee
In '87 I bought a new FXLR Custom and in '88 I added a new FXSTC. Put thousands of miles on both. The Lowrider is a great handling bike. And was easy on vibration. The Softail has great styling but not as great handling. Adding rake to a FXR would ruin the value and add little to the looks.
Old Aug 21, 2016 | 12:39 AM
TwiZted Biker
If I'm understanding what you said there anything past 1992 is fine for an evo with the counterbalanced or " B " motors starting in 2000 or so in the twin cam configuration. The late 80's evo softtails were change years and they had a couple configurations still using older style parts in the primary & drive train while nothing bad could a bit much for a novice to sort out. 1990 and up things became more commonized.
Old Aug 21, 2016 | 10:58 PM
bklynbob's Avatar
bklynbob
And well worth it......
