Please help me out if possible
Old Aug 22, 2016 | 07:01 PM
Dustin5's Avatar
Dustin5
Stage IV
Default Please help me out if possible
Id like to introduce myself, im dustin from illinois . Im passionate about harleys and love to work on them . Im having a problem ive never seen before. The compensator nut broke on my buddys bike . Now the compensator shaft is stuck on the crank with no easy way to remove...can anyone help ? Starting to get desperate and need to know if there is a tool i can buy or do i need to make something ? Any help is appreciated ..
Old Aug 22, 2016 | 07:57 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
What kind of bike are you working on?
Old Aug 22, 2016 | 08:00 PM
Dustin5's Avatar
Dustin5
Stage IV
92 fxr
Old Aug 22, 2016 | 09:02 PM
_Gir_'s Avatar
_Gir_
What do you mean it broke? Something like the external hex shape got rounded out?
Old Aug 22, 2016 | 09:08 PM
baka1969's Avatar
baka1969
Pictures will help.
Good luck.
Old Aug 22, 2016 | 09:20 PM
Dustin5's Avatar
Dustin5
Stage IV
The nut is fine ..it sheared off halfway down the threads ..leaving the inner sleeve on the crank with the other half of threads...cant get it busted loose to save my life ..maybe making a tool to surround the sleeve and lock in the slots ?
Old Aug 22, 2016 | 09:24 PM
ieatchickens's Avatar
ieatchickens
You should post this over in the "evo forum". Great bunch of guys over there. Some pretty schmart ones too.
Old Aug 22, 2016 | 09:39 PM
TwiZted Biker's Avatar
TwiZted Biker
I've had to split the compensator extension with small cutoff wheels before after somebody red loctited the hell out everything then twisted the end off the nut like yours. You cut 2 grooves half way round the shaft from each other being very careful not to get into the output shaft or the rotor then use a small chisel and tap it lightly a few times in the groove to split the halves. Get the mapp gas torch, a pipe wrench or big channel locks, heat the remainder of the nut and take it off.
Old Aug 23, 2016 | 06:34 AM
Mikey 1450's Avatar
Mikey 1450
Without seeing your situation, I will say try heat on the outer sleeve only, metal expands when hot and it might slide off
hardwork2
Apr 29, 2017 04:19 PM
gtrplyr
Mar 4, 2010 12:00 AM
