Proper tire pressure
Old Dec 17, 2016 | 09:36 AM
Redlegvzv's Avatar
Redlegvzv
Originally Posted by ChickinOnaChain
I'm actually running a lower pressure in mine to get more rubber on the road. I read that here in the soft tail section. It made sense, so I thought I'd do that.
I have been told by mechanics that this is a VERY bad idea for automobile tires. I don't know why it would be any better for motorcycles.
I run what the manufacturer says, which is the same as what my Fat Boy manual says -- 42 in the rear, 36 in the front.
Old Dec 17, 2016 | 09:40 AM
teedubbyaw's Avatar
teedubbyaw
Originally Posted by PureDeath
I run 36 on the front & 42 psi on the back, on both my bikes.
this.
Old Dec 17, 2016 | 10:05 AM
Imold's Avatar
Imold
Originally Posted by gusotto
Running too low a TP will generate heat.
Just be careful.
+1
Low pressure contributes to reduced tire life, too.
Old Dec 17, 2016 | 11:21 AM
dandrumheller's Avatar
dandrumheller
I think the recommendation to check with your tire manufacturer for proper pressures for your application is the right one. Harley's recommended pressures are for the OEM tires, those may or may not be correct for the tires you're now running.
Generally, running pressures too low will give you more contact patch (and more grip) at the expense of added heat, shorter tire life, poorer fuel mileage and uneven wear. Too much too low and you probably give up stability if the sidewalls don't have enough pressure to support them.
Running pressures too high will generally give smaller contact patch (with lessened traction and longer braking distances), probably less heat generation, and higher fuel mileage.
Always a trade off, but the manufacturer probably can provide a good, safe number as they have an interest in both rider safety and tire longevity when it comes to their reputation.
Old Dec 17, 2016 | 12:49 PM
SPRINGER's Avatar
SPRINGER
Originally Posted by Charliedontsurf
I'm going to apologize in advance if I'm in the wrong place on the site, I'm new to the forum. I have gotten some different feedback from tech vs website re: Michelin Commander II tires. I have recently picked up an 07 Dyna Street Bob and I'm kinda confused on psi. Tech says run 42 40, Michelin is at 40 30 I believe. Need some help if someone can chime in. Thanks!
I'm on my 2nd set of MC11's on my Springer and on the side of my tires I look at what the max cold pressure is and just stay a couple of pounds under that. I'm by no means an authority but I know what has worked the best on my bike.
Old Dec 17, 2016 | 07:56 PM
NORTY FLATZ's Avatar
NORTY FLATZ
This.
Old Dec 17, 2016 | 10:21 PM
FXDXTSport's Avatar
FXDXTSport
Looking at the Michelin site, they say "Respect the pressures recommended by the motorcycle manufacturer". The 2007 Harley-Davidson FXDB Dyna Street Bob has original equipment tire size of 100/90-19 for front tires with recommended tire pressure of 30.46 psi, and original equipment tire size of 160/70-17 for rear tires with recommended tire pressure of 40.61 psi. I found all this information on the internet so it has to be right
Old Dec 17, 2016 | 11:17 PM
RK4ME's Avatar
RK4ME
It makes sense that when a tire manufacturer builds a tire for a bike, they would build it to comply with the OEM load and inflation specs. Every motorcycle tire that I've used had a solo and a two-up inflation spec.
Old Dec 18, 2016 | 01:00 PM
Bingee's Avatar
Bingee
You are doing what everyone should do. Front and rear tire pressures 42 and 36 are the optimal inflation values for safe responsive handling. They're
configured that way in order to decrease the bikes tendency to oversteer. And yes it is a bad idea to ride with lowered tire pressure to increase surface contact area. That does NOT improve traction. In fact, it substantially reduces the tires ability to corner properly.
Old Dec 18, 2016 | 01:09 PM
Bingee's Avatar
Bingee
Increasing surface contact does not improve anything. In fact it will dramatically increase the tendency for hydroplaning on wet roads.
