Riding Curves
Old May 29, 2007 | 05:07 PM
ohiomotoxer's Avatar
ohiomotoxer
Default RE: Riding Curves
You will never really get the snap to snap feeling on a HD that you get on a sportbike.
The "pushing down" on the clip on's will change direction of the machine in an instant. I mean instant.
I look as far ahead as possible, your bike will travel in the direction you look.
THAT is why target fixation on a rider in front of you is so dangerous, always look around them. Ive seen allot of guys and gals go off into the toolies looking at the person in front.
For me I hardly ever use the rear brake, I am experienced in front braking and throttle control and gear selectionso turns for me are natural from my road racing background.
Most important is being comfortable with the turns, don't attempt new techniques on blind turns or in an area you never travel.
IF you are alone make the turns as straight as possible by trimming the apex (shooting inside and outside of the lane) this will take away the of turn in you need to do.
Practice doesn't always make perfect, perfect practice makes perfect.
Old May 29, 2007 | 05:14 PM
nine11c2's Avatar
nine11c2
Just an aside boys - does it pay to read both of Hough's books "proficient motorcycling" and "more proficient motorcycling" or is everything in the first covered in More (the second)...
Old May 29, 2007 | 06:05 PM
BWLucky13's Avatar
BWLucky13
Counter steering may be natural to some folks, but I suspect most riders are like me--nothing natural about it. After careful checking, it was clear that I took turns by leaning, not by counter steering. A friend who is an experienced rider and engineer told me to start actively using counter steering in curves. It still isn't natural feeling, but it really makes a big difference inmy cornering ability.
"If it seems right, you're probably doing it wrong."
Old May 29, 2007 | 06:12 PM
thrillseeker's Avatar
thrillseeker
i think there is a lot of good info here.... I just have one comment...
your fear is a reasonable one, and you should listen to it. It always takes more to control a powered machine going downhill Vs uphill.
Old May 29, 2007 | 06:14 PM
Hdbiker1450's Avatar
Hdbiker1450
ORIGINAL: BWLucky13
I kind of felt like you on this subject, until Michelle and I took a VERY familiar two lane twisty. I did the entire 11 mile stretch there and back with only the throttle hand. I was amazed to realize that I DID countersteer, without even thinking about it!
Hell, I've ridden for over 20 years! Guess you learn something new every day.
Old May 29, 2007 | 06:43 PM
jskelington's Avatar
jskelington
ORIGINAL: thrillseeker
Nice advice bud!
Old May 29, 2007 | 06:44 PM
DenimStreet's Avatar
DenimStreet
ORIGINAL: Hdbiker1450
ORIGINAL: BWLucky13
HD...did you find, like I did, that when you deliberately do it now, you have even more control and can turn even tighter?
Old May 29, 2007 | 06:47 PM
whaap's Avatar
whaap
This has been hashed and rehashed before. Any time you're traveling at roadway speeds and when you change direction you are countersteering whether you know it or not. It's impossible to turn at any speed above parking lot speed without counter steering. If you didn't countersteer you would go straight and probably end up hitting an object. Whether you think you're leaning your body or pushing with your lower bar, the effect on the front wheel is the same. Telling someone it's easier to take a turn if they countersteer is only confusing. It makes them think there are two seperate ways to make a turn and there isn't. The thing to say is that if you might be a little too hot into the corner, just push down a little more on the lower bar and that will help tighten up your turn.
However, if you establish your speed BEFORE you enter the curve there sholdn't be a problem.
Anyhow, for what it's worth, that's what we taught in the MSF basic rider course.
Old May 29, 2007 | 06:58 PM
DenimStreet
ORIGINAL: whaap
Whaap, I agree 100%. We all counersteer and it is the only way to turn. People lean too and don't need to. What I am saying is....once you are aware that you are countersteering, and INTENTIONALLY do it, you have more control and tighter turns. I don't think it is necessarily a good thing that people are doing it unconsciously.
Old May 29, 2007 | 07:01 PM
whaap's Avatar
whaap
Agreed. The more riders that understand what's going on the easier time they would have doing it.
