Battery tender question
Old Feb 12, 2017 | 04:49 PM
  #31
confederate's Avatar
confederate
Most Wanted
Talking
Originally Posted by TinCupChalice
You got it, my friend I've never heard this bike spin up so fast, that GYZ20HL and those Terry Components battery cables are must haves
The first time I started her after installing the battery cables and the Yuasa I thought I'd done something wrong for an instant; it never sounded like that when I hit the start button!
No kidding!!! My bike has never started the way it does now with this battery. My dad who is total "old school" was also surprised and impressed when we did the comparison between the two batteries. He is also going to switch over to Yuasa for his Road King. Can't wait to hear that one crank lol.
Old Feb 12, 2017 | 05:15 PM
  #32
bettingpython's Avatar
bettingpython
My next battery will be a Yuasa on the RGU. I travel way to far to depend on a subpar battery.
That being said I have always had good luck with batteries from batteries plus. The Duracell agm was far better in my 13 SG than the factory battery.
Old Feb 12, 2017 | 05:16 PM
  #33
TinCupChalice's Avatar
TinCupChalice
Confederate, I do admit, it startled me for a moment when I hit that start button for the first time
Put these in your back pocket when you're feeling froggy and want even more out of that Yuasa: http://www.phatperformanceparts.com/.../2113-0269.htm
The auxiliary that goes under the seat will feed off the negative battery side instead of the transmission side but it won't make any difference at all; you will need to crimp on a loop connector for the auxiliary but these 4 gauge battery cables do seem to lower the voltage drop on startup even further
Old Feb 12, 2017 | 05:20 PM
  #34
bettingpython
P.s. get yourself one of those battery jumper packs. Those things are amazing. As long as the battery isn't internally shorted and has enough charge to make the starter click they work. I've started a couple of bikes and V6 mustang with my lightning pack. Almost managed to start a 5.4 ford but just not big enough.
Im also popular with my friends whose phone batteries die they always borrow my jumper pack.
Old Feb 12, 2017 | 06:08 PM
  #35
triumph900's Avatar
triumph900
I know the owners of Battery Mart. Good folks!
Old Feb 12, 2017 | 06:21 PM
  #36
golfblues's Avatar
golfblues
Deleted
Old Feb 13, 2017 | 01:25 AM
  #37
JekyllnHyde's Avatar
JekyllnHyde
There is a difference Yuasa GYZ series; the highest rated AGM battery for our HD's. The GYZ20HL in my Wide Glide was fresh in the pipeline and is now rated at 320 CCA and 20Ah.
http://www.phatperformanceparts.com/.../yuasa-gyz.htm
What he said. ^^^ I have the same battery on my '08 Low Rider as well as on my Softail. Going on 6 years on the Low Rider and 3 years on my Softail and no issues with either....both still crank up strong. All my bikes are on a battery tender while they're not being ridden. Once I pull them in the garage I hook them up.
Old Feb 13, 2017 | 04:39 AM
  #38
Mxdad's Avatar
Mxdad
Originally Posted by From_Behind
If you've had this battery in your bike since '08 and it's just now giving you issues, I'd replace it with the exact same thing!
Man I am with you on that, if that battery gave you almost 10 years of service get the same one again
Old Feb 22, 2017 | 09:33 PM
  #39
golfblues's Avatar
golfblues
Got the Yusa today. 320CCA. Nice deal at 86 and change. It was over boxed but they should have put more packing in the larger box as it was sliding around. It is in 1 piece
I won't get to try it for a while as I'm waiting for one of my older batteries to bite the dust.
Old Feb 22, 2017 | 09:48 PM
  #40
Cousy's Avatar
Cousy
I don't see where the $86.95 figure is coming from. YUAM720GH is $121.95 on the phat performance parts link.
