Flht 03
Old Feb 19, 2017 | 07:16 PM
Mark Break's Avatar
Mark Break
Stage IV
Default Flht 03
question. Had the clutch lock nut come loose. Readjustmented the clutch and cable. Road about 50 miles. Lost power to the wheel. Belt is good motor is fine. No noise or chatter. Took derby and inspection cover and primary chain is intact. Looking for suggestions for where to look next. Thinking behind clutch cable housing. But am confused because I had clutch and was riding with no problems or noises. Open to comments. Please and thanks.
Old Feb 19, 2017 | 07:28 PM
PeterV's Avatar
PeterV
Loosen clutch cable, squeeze clutch lever several times make sure there's positive contact to pushrod and spring. Re adjust adusting hex screw for positive contact with rod then back off 1/2 turn, tighten jam nut, adjust cable slack.
Old Feb 20, 2017 | 07:00 AM
Mark Break's Avatar
Mark Break
Stage IV
I can see the clutch engaging and disengage. Is it possible that I had over tighten and glazed the clutch and with having over 70000 on original plates just finally wore the the plates out that fast ?
Old Feb 20, 2017 | 12:31 PM
PeterV's Avatar
PeterV
Are you getting zero engagement?
Pull the plates and discs have a look
HDF Tech
217
Sep 7, 2023 09:07 AM
Subduedracer
Jul 31, 2013 10:38 PM
Port Dawg
Jul 20, 2011 03:36 PM
gmspd
Sep 2, 2010 08:36 AM
jdusty21
Ironhead
Nov 5, 2007 05:28 PM
