How much compression is too much?
Old Mar 17, 2017 | 08:15 AM
sharkey's Avatar
sharkey
Last 4 builds friends and I have done have all used S&S E-Z starts. If you have kickback your gonna wreck stuff in a hurry; I did a long way from home and it cost me dearly.
As far as hard starting; I don't want to dis independent shops, but I think a lot of money is made selling parts to address SYMPTOMS afterwards; bigger starters, bigger batteries, bigger cables, heavy duty this and that...when all that's really needed is proper ignition timing and less cranking pressure via comp releases of some sort.
That's my two bits; been there, spent that.
Old Mar 17, 2017 | 08:35 AM
RHPAW's Avatar
RHPAW
Remember that anything you do affects the rest. Harder on the starter to turn that compression. I keep mine dialed-in, so it doesn't turn over hardly at all before it catches and starts up.
Old Mar 17, 2017 | 08:42 AM
smitty901's Avatar
smitty901
Originally Posted by chaselee
Im getting ready to do a 95" v twin kit with 10:5-1 wiseco pistons in it. My indy swears that I wont need compression releases and that hes done this kit before with no problems, but I just wanted to get some others opinions. Afterall, that's a pretty big jump in compression from 8:9-1 to 10:5.1. Last thing I want is an unreliable bike that's hard to start. Thanks for your input.
You said it he is an Indy. Yes you do need compression release. It will be hard on batteries and starter. Putting a bigger battery or stronger starter will not fix the problem. Why do you think HD went to installing ACR from the factory. Of course Indy will tell you HD don't know nothing .
find a skilled experienced shop to deal with.
Old Mar 17, 2017 | 08:56 AM
LiiT's Avatar
LiiT
The OP never mentioned cams with his upgrade. It seems we are assuming he is going to change those out as well. A lot will depend on that.
A lot of independent shops are run by guys who used to work for Harley and/or have been trained in working on them. It's just wrong to cast them all under a certain light.
Get your facts straight.
Old Mar 17, 2017 | 09:04 AM
Uncle Larry's Avatar
Uncle Larry
S&S Easy Starts are an option ... Doing the Compression Releases will hurt nothing and will DEFINITELY extend the starter life and ease of starting, especially on those hot summer days.
Old Mar 17, 2017 | 09:06 AM
LiiT's Avatar
LiiT
Yep, and probably add less than $200 to the total cost of the build.
Old Mar 17, 2017 | 12:16 PM
RK4ME's Avatar
RK4ME
I went with a conservative 95" build that doesn't look like much "on paper" but the additional compression definitely shows up when I crank it over, and it WILL shorten the life of the starter.
Old Mar 17, 2017 | 02:18 PM
LiiT's Avatar
LiiT
Here's the dyno sheet on my 95" build with the 509 cams.
Attachment 520772
Old Mar 17, 2017 | 02:46 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Go "too high" on compression and fueling & cooling become issues.
Old Mar 17, 2017 | 04:35 PM
dyna rider's Avatar
dyna rider
Default Compression Releases
I did a 95" kit to my 06 Dyna SB and put high compression pistons in. I believe they ran about 10.1-1. The higher compression wakes the cams up. First rounds of mods put out, there again about 85hp and 93 ft pds torque. I did not have the heads drilled for crs but I could feel the bigger load on the starter. When I put different heads on the motor, they were already drilled for releases. Like a few folks said, they will not hurt anything so why not do it ? May save time and money later.
BTW When I use my manual crs, I always open them right after I shut the engine down...They will get hotter the longer they sit on a hot motor. The 211 cams have great low end torque so go for it.
