Harley Fork Oil...Which Type
Old Apr 25, 2017 | 03:14 PM
RoadGlide&48's Avatar
RoadGlide&48
Default Harley Fork Oil...Which Type
I'm replacing the lower sliders on my 15 RGS. I see Harley offers three different types of fork oil? Which one should I use and why?
Old Apr 25, 2017 | 05:31 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Ask someone at the shop where you're going to buy it.
Old Apr 25, 2017 | 05:34 PM
josame's Avatar
josame
I put some of the heavy Harley brand fork oil in my 11 Road King. I put in the same amount that I got out so I know didn't over fill it. Man it was harsh, I ended up draining about half of that out and adding some of the lighter weight oil to soften it up and it was much better.
If I remember right there are 3 different weights of oil Harley sells but they don't say what weight they are. I'm thinking they are 5, 10 & 15 wt.
I think I would stay away from the heaviest oil.
Old Apr 25, 2017 | 06:40 PM
RK4ME's Avatar
RK4ME
This is what I run in my '04 Road King, and it's what a local dealer recommended. The forks feel a lot better than they did with the original fork oil.
http://www.harley-davidson.com/store...eagle-fork-oil
Old Apr 25, 2017 | 06:57 PM
Bone Doc's Avatar
Bone Doc
I use the same fork oil in my 2012 Heritage. I began using it when I installed my chrome front end kit. I like it better than the stock fork oil since I get less brake dive with it.
Old Apr 25, 2017 | 09:40 PM
NORTY FLATZ's Avatar
NORTY FLATZ
You can certainly mix different viscosities to create a custom blend if needed.
Don't want your forks to "dive" during braking? Add spring.
Old Apr 26, 2017 | 03:10 AM
Bone Doc's Avatar
Bone Doc
I agree. I only changed to a heavier oil to help with dampening, not to reduce brake dive. It was just something I noticed with the heavier oil.
Old Apr 26, 2017 | 06:06 AM
Notgrownup's Avatar
Notgrownup
Depends on your load...how heavy is the load on the bike , if you weigh 300 lbs 2 up soaking wet then the heavy oil might be too harsh for you..compared to 450 lbs like us...I like about 10wt, last time I mixed bel ray 7 and SE racing fork oils, it was perfect.
Old Apr 26, 2017 | 06:33 AM
josame's Avatar
josame
Thats a good point. I'm 165# wife is 110# thats probably why the heavy weight oil was harsh for us.
Old Apr 26, 2017 | 07:00 AM
T Man's Avatar
T Man
I get noticeable braking dive, was going to order springs but my dealer said try SE oil first because it will produce a noticeable difference. I haven't done it yet, but I was impressed that they were trying to save me some $.
