Turn signals won't flash
Old Jun 5, 2007 | 02:15 PM
vabubba's Avatar
vabubba
Default Turn signals won't flash
I installed some new turn signals on my bike las night. It was getting kinda late, but I thought I could git r done in about an hour or so. I soldered and heat shrinked all the joints and removed the factory signals from the rear fender strut. Buttoned it all back up and the lights will come on but not flash. I suspect it is a difference in the electrical load that the replacement turn signals verses the factory ones. The new ones use a 194 peanut bulb and I believe the factory used a 1156? Any way to get these things flashing? Any help would be appreciated. TIA
Bubba
Old Jun 5, 2007 | 02:16 PM
sleepneagle's Avatar
sleepneagle
Default RE: Turn signals won't flash
probably need a load equilizer.
Old Jun 5, 2007 | 02:19 PM
fxrsjohn's Avatar
fxrsjohn
I had a similar problem. Relay went bad. they are about 135.00 if that is the problem.
Old Jun 5, 2007 | 02:27 PM
vabubba's Avatar
vabubba
ORIGINAL: fxrsjohn
I'm thinking it's not the relay because they were working great prior to me fudging with it. Is there a specific load equalizer for this type of set up or are they more generic?
Old Jun 5, 2007 | 03:14 PM
vertigo14's Avatar
vertigo14
try unplugging the new ones(not removing them) and plugging back your old ones, see if they work. If they do its not your relay...
might try a load equalizer... they 30bucks or so... are you sure all your new connections are soldered well?
my Kuryakyn LED mini bullets(strut mounted) didn't have any problems and that's quite a bit of electrical draw than the stock ones
and I didn't need a load equalizer either.
Old Jun 5, 2007 | 06:37 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
You need a load balancer. They are generic.
tyrantjon
Apr 1, 2014 02:38 PM
dkfxr
EVO
Sep 2, 2013 02:38 AM
Chase1961
Jul 10, 2013 09:48 AM
utnick3
Electrical/Lighting/Alarm
Jan 25, 2013 02:44 PM
Wakko47
Mar 23, 2012 04:52 PM
