M8 or Rushmore
Old Jul 12, 2017 | 07:26 PM
  #41
not a sock's Avatar
not a sock
Originally Posted by Dynamick
In the list above, only the first two items (engine and suspension) are changed for '17. All the other items were available on the '14-'16 Rushmores.
If we're going to help the OP make an informed decision, might as well give him correct information.
What would we do without your help in pointing that out?
As the OP said, 'he doesn't have a Rushmore."
Maybe he doesn't know about those 'other things'...............
Old Jul 12, 2017 | 09:12 PM
  #42
martinj's Avatar
martinj
Originally Posted by HDMIKETN64
Rushmore is styling and comfort features. Absolutely nothing to do with the engine. With the only exception being the 103 HO which IIRC was only available in touring (AKA Rushmore) bikes. And not all Baggers are Rushmores. But all Rushmores are baggers. LOL
This is not quite accurate. The 103 HO was (is) air cooled and was installed as standard on LowRiders, some other Dynas as well, and in most Rushmore models. The remainder (Ultra Limited, Tri Glide Ultra and CVO Limited) got the Twin cooled engine (rather than the 103HO), which was essentially a 103HO with liquid cooled heads and slightly higher static compression. So yeah, the higher performance engine actually was an integral part of the Rushmore package as far as it concerned Twin Cam models.
Old Jul 12, 2017 | 09:46 PM
  #43
HDMIKETN64's Avatar
HDMIKETN64
You are correct, sir. I was over generalizing. The 103 HO was installed in the touring bikes, unless it was water cooled, in which case it was the twin cooled model. It also did appear in other models as well.
Old Jul 12, 2017 | 10:34 PM
  #44
martinj's Avatar
martinj
I get that. I do it myself on occasion. With that said, it was not my intention to come off sounding critical.
Old Jul 13, 2017 | 01:07 PM
  #45
mmancuso's Avatar
mmancuso
Originally Posted by StoneyFatBoy
Harley just did a recall on 57'000 m8's for an oil line defect on all bikes built between July 2 2016 to May 9 2017 so if you are getting an m8 make sure that's been fixed
There was no oil line defect (2017 RK): a clamp may not have been properly secured on the end of one oil line....mine was fine.
That M8 is AWESOME!
traveler
Jan 28, 2020 02:52 PM
Sidneyg
Jul 27, 2019 02:11 PM
Ericson38
Milwaukee Eight (M8)
47
Sep 29, 2018 09:54 PM
doug62
Dec 17, 2016 02:05 PM
Tucker99
EVO
70
Jun 5, 2012 12:02 PM
