Help with choke cable
Old Jun 13, 2007 | 03:11 PM
TJ461vs's Avatar
TJ461vs
Default Help with choke cable
The *** on my choke cable broke on a 1200 custom so I need to replace the cable with anew one. The service manual doesn't say anything about how to replace the cable. This morning I was looking at it and I had the air filter assembly off and it appears that I may have to remove the gas tank to access the area behind the carb where the cable attaches. Has anyone had any dealings with replaceing their choke cable? Any tips to make this a simple repair instead of removing the gas tank?
Thanks
Old Jun 13, 2007 | 03:27 PM
Steve On 3's Avatar
Steve On 3
Default RE: Help with choke cable
Take the carb off. It's a small ball on the end of the cable that fits into the carb. Be careful tightening the plastic nut that holds it onto hte bracket at the ****. It will break if tightened too much. No need to ask me how I know. I had mine replaced while having some other work done. WOuld have done it myself if the damn manual had said anything
Bubba
Old Jun 13, 2007 | 03:35 PM
TJ461vs's Avatar
TJ461vs
Thanks Bubba! I'm off to remove the carb now.
TJ
Old Jun 14, 2007 | 05:22 AM
bluesdude's Avatar
bluesdude
I can't find my choke cable or choke for that matter. J/K
Old Jun 14, 2007 | 12:00 PM
TEK 679's Avatar
TEK 679
That choke **** is cheap, easy to break. I broke mine the second month, didn't bother taking it back to the dealer, replaced it with a radio volume **** no kiddn' , how does it look?
They don't sell the choke **** by itself, you have to get it with the cable, that's why I keep the cable and put a replacement ****, less work.
_____________________________
If it ain't broke, fix it till it is.[sm=badidea.gif]
bharvey60
Apr 17, 2012 09:49 AM
patsfan05488
Mar 28, 2011 08:27 PM
Classic Eagle
Carburetor Related
Aug 31, 2009 08:28 PM
jackietan
Apr 25, 2008 01:05 PM
tommylee44
Apr 7, 2008 03:34 PM
