So I have been checking out blow driers for the bike and came across this Toro unit from home depot. Has anyone ever used this model and what are your feelings about it? For 30 dollars it cant be that bad can it?
Here is a link to their web site
http://www.homedepot.com/webapp/wcs/...cStoreNum=8125
[*]Amperage: 7 Amps[*]Assembled Depth (In Inches): 8.87 In.[*]Assembled Height (In Inches): 19.25[*]Assembled Weight (In LBS): 5.8[*]Assembled Width (In Inches): 12.87[*]Cubic Feet Per Minute (CFM): 170 CFM[*]Engine Displacement (cc): 0 cc[*]Engine Torque (Ft./Lb.): 0[*]Fuel Type: Electric[*]Handle Length: 6 In.[*]ITEM DEPTH (In decimal format): 12.87 In.[*]ITEM HEIGHT (In decimal format): 19.25 In.[*]ITEM WEIGHT (In decimal format): 6.5[*]ITEM WIDTH (In decimal format): 8.87 In.[*]Interchangeable Tips Available: No[*]Recommended Oil & Capacity: N/A[*]Rust resistant Y/N: Yes[*]Rustproof: No[*]Start Type: Other[*]Vac Capable: No[*]Weight: 4.9 Lbs.[*]Weight: 4.9 Lbs. [/ul]
Bought the same one from Lowes.....works great so far. I can dry my Deuce in about 10 minutes tops. I use it on the vehicles also, my F-250 and the wifes Expedition, quick dry time!!!!!
Since I work for TORO I am biased also get discount. Check out www.shoptoro.com
Here's the best model Toro Has....$69.95
Works like a charm 220 mph!
You can't buy a more powerful handheld blower, gas or electric. The all new Toro Ultra 225 delivers all the power and all the versatility you need to tackle your every clean-up chore. It is the only electric blower vac to offer a rugged metal impeller and an infinitely variable speed motor! With a soft-grip handle for ergonomic comfort, you can blow, mulch (16:1 ratio) or vacuum - all with easy no-tool conversion. Backed by a full 2-year warranty, this is the ultimate blower/vac for the ultimate homeowner.
[*]Brand : Toro[*]225 mph maximum air speed[*]Infinitely variable air control[*]3 In. 1 machine- blower, vacuum, leaf shredder[*]Metal impeller for mulching[*]Reduces 16 bags of leaves down to 1[*]Comfort-Control Grip[*]MFG Brand Name : Toro[*]MFG Model # : 51598[*]MFG Part # : 51598 [/ul]
