Ignition issue
Old Mar 25, 2018 | 12:39 PM
Steve Stephani's Avatar
Steve Stephani
Stage IV
Default Ignition issue
I have a 2007 Street glide that I put 10 inch twin peaks handle bars on it. It been sitting all winter not trying to start it it only fires on the front cylinder. No spark on the rear cylinder. Coil test good a long with the wires any thoughts would be greatly appreciated.
Old Mar 25, 2018 | 04:53 PM
dawg's Avatar
dawg
I assume that the problem arose after the handlebar change? If so, retrace your steps and check the wiring you worked on in doing the bar change.
Old Mar 25, 2018 | 06:24 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
First swap plug wires and see if the problem moves.
If it does get new wires. If it doesn't get a new coil.
I had a coil that passed all the tests but still wouldn't fire, I replaced it with a new OEM coil and it lasted 8 miles, replaced that one with an aftermarket one and it's still going strong.
I can't think of anything in a handle bar change that will cause a bike to run on one cylinder.
OP what I posted above applies to dual fire ignitions.
Not sure if you have one or not but if you have single fire it won't help you a bit.
I'd suggest getting a new coil just in case.
Old Mar 25, 2018 | 09:44 PM
Steve Stephani
Stage IV
I've switched wires at the coil and the problem moved so I put a different coil on and the problem continues. I'm wondering if the pcu is in a limp mode. I've probed all wires in the new bars and found shorts to gound. Normally I would expect that it would be ignition module but that's run through pcu please someone correct me if I'm wrong. Any more information from everyone would be greatly appreciated
Steve Stephani
Stage IV
I found no shorts to ground
Old Mar 26, 2018 | 08:28 AM
texashillcountry
Dirt don't hurt
Have you ohmed out the spark plug wires?
Old Mar 26, 2018 | 08:49 AM
Steve Stephani
Stage IV
Yes wires tested good
Old Mar 26, 2018 | 10:32 AM
DanRC's Avatar
DanRC
If the problem moves from back to front when you switch wires, it would suggest the wires are bad.
Puzzell
EVO
23
Jun 9, 2020 05:38 AM
CatWoman
EVO
38
May 5, 2017 08:30 PM
splittie65
EVO
30
Apr 16, 2015 06:21 PM
dts
Aug 17, 2007 06:15 PM
jhnmflr
Jul 5, 2005 08:31 AM
