To clutch or not to clutch.
Old May 14, 2018 | 08:52 AM
JerseyDoug's Avatar
JerseyDoug
Do I hold the clutch in through or part way through a turn? No. Do I feather the clutch as needed to control speed through a low speed turn. Yes, if I need to.
I've taken two riding courses and they both taught feathering the clutch and rear brake control for slow speed turns.
Do I mess up sometimes? Yep.
Old May 14, 2018 | 09:11 AM
stixvrad's Avatar
stixvrad
Originally Posted by Steevo Jolly
I'm sure this will bring some debate. My wife just finished her class at the local dealership. What was throwing her was the instructors insistence that the bike be fully in gear when making a turn. She was feathering her clutch through sharp right hand turns from speed.
I understand why this could considered dangerous or improper. I went out for a ride and tested it myself and love and behold I do the same thing. Going from X gear at 55mph and dropping down to second to navigate a right hand turn I always held the clutch in through the apex and release as I accelerate out of the turn. To get the bike fully in gear and turn without the clutch was very strange to me and impossible unless I tried really hard. It felt so foreign.
so question is. Do you hold your clutch in while making sharp turns or do you let the rom drop way down while staying in gear?
If its a bus stop ( real slow and sharp) turn, and if the situation calls for it ( real rough ,bumpy road, loose dirt or gravel , downhill) I'll let the bike coast through, clutch in. If its bumpy and slow, it can be difficult to modulate the throttle smoothly. Which makes loose sand or gravel become a low speed tip over. If its a normal bend in the road, no I always leave the rear wheel under power.
Old May 14, 2018 | 09:51 AM
bradleys's Avatar
bradleys
Yeah, I downshift and feather the clutch into the apex of the turn using the engine as a break and then accelerate coming out of the turn. I think you are able to come into the turn a little hotter this way. Coming into the turn in gear would require you to drop speed before the turn, not while you are in the turn.
It is probably safer to do what her instructor is recommending - especially for a new rider.
Old May 14, 2018 | 10:55 AM
67Shuv's Avatar
67Shuv
I always make sure I'm in the correct gear with my clutch hand free to wave to other riders! I'll be damned if I miss one!!!
Old May 14, 2018 | 11:06 AM
BLMC's Avatar
BLMC
Clutch out and higher RPMs allow me to make tighter turns w/ less lean angle, translating to faster turns. It is all about physics and geometry, working with, not against.
Old May 14, 2018 | 11:37 AM
uncle kebo's Avatar
uncle kebo
We're answering 2 questions at the same time - The OP asked about turns, were responding to curves and turns which depending on situation are 2 different answers...
Old May 14, 2018 | 11:40 AM
larsfum's Avatar
larsfum
Regardless of a curve or a turn, at speed the actions are the same.
I was always taught to Slipper it through a turn. Clutch out the whole way.
SLPR
Slow when approaching the turn. Shift into correct gear
Look Where you are going.
Press Handlebar into the turn. Right turn. Right bar. Left turn. Left bar.
Roll on the throttle at the apex to come smoothly out of the turn.
Always works for me at any speed. The only exception is very slow maneuvers. Then it's feather the clutch, keeping the throttle in the friction zone. Look when I'm going, and drag the rear brake a bit.
Old May 14, 2018 | 12:07 PM
RK4ME's Avatar
RK4ME
If the vehicle is in motion, the clutch/driveline is engaged unless you're changing gears or coming to a stop. If the clutch isn't engaged, you're coasting, and you don't coast through corners or turns.
Old May 14, 2018 | 12:36 PM
Mastiff107's Avatar
Mastiff107
What in the hell are folks doing with clutches!! This is the dumbest **** I have ever heard (bearing in mind that on occasion I have actually listened to what my wife was saying!) . Are they clutching on turns in stick shift cars? It isn't like your Johnson, it's not there for recreation, it's for shifting! For those who keep saying "on a sport bike" they should be beaten and their bikes taken away....a bike is a bike is a bike. No wonder those kids are wrecking sport bikes all over the place. Calm down, learn what you are doing and don't just hop on and start wildly grabbing stuff ( actually my wife told me that one long ago). If you are going to shift, engage the clutch, shift and disengage the clutch. That's it..
Old May 14, 2018 | 01:12 PM
dribble's Avatar
dribble
Even when riding motocross or desert? My clutch in those situations is like an extra gear between gears.
