Harley General Torque specs
Old Jun 4, 2018 | 05:21 PM
barneyboy's Avatar
barneyboy
Originally Posted by OGBlackout
Yea I can’t wait until it comes in on Wednesday, impatiently waiting lmao. But yea figured I could buy the heavy duty wrench if I ever needed it.
I wouldn't worry about a heavy duty wrench either, you may never need it. If you plan on performing your own "regular" maintenance, an inch-pound wrench will be needed for the smaller fasteners (ie. master cylinder cover screws, etc.), which are frequently overtightend by a novice. On the other hand, most (if not all) models require more than 80 ft.-lbs. on the rear axle, after a belt/chain adjustment.
Old Jun 4, 2018 | 05:49 PM
Zerk's Avatar
Zerk
Figure going to need a new rear tire every 10k miles. More in hot areas probably. But not like you have to buy it today.
Old Jun 4, 2018 | 07:48 PM
skratch's Avatar
skratch
I just got a Sportster 48, I know its not the best out there but....
let me interrupt you right there. i don't care if it's a sportster, a street, a dyna, or a friggin vespa, it's your bike, be damned proud of it. when you buy a new bike, it won't necessarily be an 'upgrade', it'll just be a different tool, adapted for a different job.
Old Jun 4, 2018 | 10:09 PM
Zerk's Avatar
Zerk
Damn right, it is yours.
Old Jun 6, 2018 | 02:57 PM
nytryder's Avatar
nytryder
Originally Posted by dawg
If you plan on doing rear wheel removal or some of the sprockets, you’ll want a bigger one. I use three torque wrenches, an inch pound, a foot pound up to 75 and then a big one up to 200
This for sure. Or you can pick up a Beam style Torque wrench, that will measure from zero to approximately 150 Ft #s of torque. These wrenches are very affordable and very accurate. Also keep in mind a little less torque is generally preferable to a little too much.
Old Sep 1, 2023 | 05:02 AM
abcuros's Avatar
abcuros
Stage II
For most Harley-Davidson motorcycles, an 80 ft-lbs torque wrench will cover many of the tasks, especially those related to general maintenance. However, there are certain components, such as the main engine mount bolts or the axle nut, that might require more than 80 ft-lbs of torque. To ensure you're prepared for all tasks, you might want to consider a torque wrench that goes up to at least 100-120 ft-lbs.
Check your service manual for specific torque values for your bike model, and based on the highest value, you can decide if you need a stronger torque wrench. Safe riding and wrenching!
Old Sep 1, 2023 | 05:05 AM
M Oclaf's Avatar
M Oclaf
Do not use on oil drain plug…J/S
Old Sep 1, 2023 | 07:05 AM
bduds65's Avatar
bduds65
I cannot speak for any of the technical upgrades and service details. No apologies, I just ride.
I shared this story about new handlebars put on my bike during the purchase (February) a few years ago. Delivery in March so I finally took her on the road for a test ride in April. Maybe a half mile down the road, I am now looking at the road in my mirrors because my handlebars were not tight and slipped. WTF! So having only an old rusty Allen wrench I tightened them the best I could. Went another 10 miles and everything was just fine.
So I took the bike to a local HD shop (not the dealership I purchased from, 2 hours away) and asked for a once over and tighten the riser/clamp to HD specs. So a week later on a group ride, I get about 3 miles down the road, same thing. Tighter and not "sloppy" but not right. I was able to get through the ride, but I gave up. I am now tightening this as much as I can. Hopefully I wont strip anything and nothing will break. Has been fine since. I check it once every few rides to be sure.
So I took it to a local custom shop. New to us. The guy was very knowledgeable and seemed trustworthy and came recommended. So getting a new rear tire, I asked him to check the clamp. So picking up the bike yesterday he says they were very loose. You need a wrench with a long arm to tighten those bolts properly. NOT NECESSARILY a torque wrench. He shared some examples of things I honestly didn't understand, but the upshot was that most Harley torque specs are BS.
I don't even know what or who to believe anymore!
Old Sep 1, 2023 | 11:23 AM
skratch's Avatar
skratch
depending on your handlebars, the stock torque specs may have been bs. remember, hd specs are based on stock equipment, not custom mods.
Old Sep 1, 2023 | 11:27 AM
M Oclaf's Avatar
M Oclaf
A little blue loc-tite works wonders on bolts such as those. Every bike I owned has had that as once I set them, it’s rare I touch them again.
